Fuses
Discussion in '2.5 Gen Tundras (2014-2021)' started by joeyinthesky, Jan 1, 2021.
  1. Jan 1, 2021 at 11:59 AM
    joeyinthesky
    joeyinthesky [OP] New Member
    2016 Crew Max Limited 5.7L
    My display panel (gauges) are not lit, neither am I able to adjust them with the dimmer switch. Is there a fuse for them and if so, which one. I'm trying to avoid having to go through the process of elimination.
    Mine is a 2016 Tundra Crew Max Limited 5.7L
  2. Jan 1, 2021 at 12:36 PM
    18" TRD Off Road Wheels
    I won't be able to help you, but I know the first question the gurus are going to ask.
    1. What year, cab, and engine is your truck?
    Fuse locations and such have changed through the various model years. Gotta give them a bit more to go on.
  3. Jan 1, 2021 at 12:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Is there any chance you have a twilight sensor and is it blocked?? easy way to tell is that your headlights are on when your truck is on. There should be a fuse panel underneath the dash, you may need to do some gymnastics to get in there though. While you're there you can try and see if the harness has been pulled off accidentally, or damaged...
  4. Jan 1, 2021 at 12:51 PM
    joeyinthesky
    Will do, thank you.
