Fuse location for trailer hookup / 7 pin connector power?
Discussion in 'Electrical' started by Locke504, May 9, 2022.
  1. May 9, 2022 at 9:34 AM
    Locke504
    Locke504 [OP] New Member
    Hi all,
    I'm trying to figure out exactly which fuse controls power to the 7 pin connector hookup on my 2020 Tundra. All the trailer running lights are working but when I plug in my electric trailer jack, it is not getting power.
    It's not the jack (my dumb ass bought a new one thinking it was) so I think it must be the fuse.
    Appreciate any guidance, thank you.
  2. May 9, 2022 at 3:17 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I believe you are talking about connector R18.
    This is my interpretation of what each pin is form the diagram below
    1) Left Turn
    2) Tail Running Lights
    3) Ground
    4) Reverse Lights
    5) Battery Power
    6) Brake Lights
    7) Right Turn
    I think you are looking for Aux power at the pin which would actually be on Pin #5 and not Pin #7
    You can see Pin #5 is power coming from the 40A Sub Batt Fuse. However a relay activated by the 5A ECU-IG1 No2. fuse allows the power to flow from the 40A fuse into Pin #5.
    First thing I could do is get a voltmeter and check for voltage on Pin #5. Then check both fuses listed above.
    Locke504[OP] likes this.
  3. May 9, 2022 at 3:21 PM
    Locke504
    Exactly what I was looking for! Thank you very much.
  4. Jul 23, 2024 at 7:29 AM
    larlap
    larlap New Member
    Larry
    Illinois
    2008 Toyota Turnda
    Did you figure this out? I'm looking at my fuse panel and seeing a large bar across where my 40A sub bat fuse should be. I pull an RV and everything works as it should except it's not getting 12v to keep the fridge running and RV battery charged... There's no socket to plug in a 40a fuse. Unless I have the wrong fuse location....PERPLEXED....
