Fuse Diagrams
Discussion in '2nd Gen Tundras (2007-2013)' started by Austringer, Dec 3, 2021.
  1. Dec 3, 2021 at 12:49 PM
    Austringer
    Austringer [OP] New Member
    2007 Double cab 4WD,78" bed, silver,5.7 liter
    K&N air filter. Clean mass air flow sensor. Put on a set of Michelin Defender LTX-MS tires. put Snake Oil in engine. All trying to get better gas mileage. Put Plano box in bed behind cab and bolted it to the bed
    I tried to put some LED lights in my 2007. Blew fuses.I called and apparently you have to have another flasher unit, the stock one won't work. I got tired or it and put the bulbs back in. Guess what it won't start. I have checked ever fuse that's involved with the ignition, and they're all good???????????????????
    Does anyone have the drawings of the fuses? 2007 Dbl Cab 4WD.The one I have isn't the same as my truck. Thank you.
