Fuse box question
Discussion in '2.5 Gen Tundras (2014-2021)' started by BuckWallace, Jul 5, 2018.
  1. Jul 5, 2018 at 6:21 PM
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    So I hardwired a dash cam and went the add-a-fuse route, but I'm wondering which side of the fuse box by the kick panel is "hot". I know it matters which way you insert the add-a-fuse l, but someone is borrowing my multimeter so I can't check at the moment. I'm wondering whether the side with the yellow line or the red line is the hot side in the pic below?
  2. Jul 9, 2018 at 11:50 PM
    ZPMAN
    Minnesota
    BuckWallace[OP] and texasrho83 like this.
  3. Jul 10, 2018 at 6:00 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    texasrho83 likes this.
  4. Jul 10, 2018 at 7:00 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Interesting. I just recently re-wired every accessory in my truck and decided to add a separate fuse block to run everything to. I don’t think I’ll ever run/tap into any factory harness/fuse again after going through 2 body ECUs ($900 a pop - pun intended)
  5. Jul 10, 2018 at 8:04 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Cool, thanks. You said you shorted out the fuse, so I assume that wire you added is going directly into the "hot"/power side (not actually being protected by the fuse). I actually made a little test light and came to the conclusion that the side you have your wire plugged into in that pic is indeed the hot side. Thanks again.
  6. Jul 10, 2018 at 8:15 AM
    Tundradrenalin
    Virginia Beach, VA
    Sep fuse block :laser: is def the best way to wire any accessory, if you have the means
  7. Jul 10, 2018 at 8:56 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The fuse block was pretty inexpensive. All it takes is time...and plenty of wire & connectors ;)
  8. Jul 10, 2018 at 9:51 AM
    ZPMAN
    Minnesota
    You are correct, its for the bully dog and it has its own fuse.
  9. Jul 10, 2018 at 10:00 AM
    ZPMAN
    Minnesota
