Fuse block location for 2018 Tundra??
Discussion in 'Lighting' started by jamano2009, Jun 27, 2018.
  1. Jun 27, 2018 at 11:52 AM
    jamano2009
    jamano2009 [OP] New Member
    Joe Lombardo
    I just replaced my 07 Tundra with 243,00 miles in it (Sad day :( ) bought myself a 2018 Tundra and bought myself some nice LED interior lights.
    ******WARNING****** DO NOT REPLACE LIGHT WHILE LIT!!!!!!!!! lol
    I proceeded to blow a fuse, referred to manual with no luck, looked on line with no luck, then I found this site. Can anyone tell me where the interior fuse block is located on my truck. The only thing I found was for a 2016 which appears to have been relocated??
  2. Jun 27, 2018 at 11:55 AM
    Should be two
    1) engine compartment
    2) Driver side kickpanel.
    Marty McFly likes this.
  3. Jun 27, 2018 at 12:14 PM
    jamano2009
    Joe Lombardo
    Engine compartment is a negative, I will check kick panel, nothing marked on exterior, need to look closer, thank you!!!!!!!!!!!
    The closest I found was on 16 which was under driver side dash has been changed apparently, thanks again T-Rex266!!
    I let you know how I made out, great response time btw!!!
  4. Oct 30, 2019 at 12:50 PM
    WriterLeft
    WriterLeft New Member
    Man...I had the same problem. Had to go to Toyota and bend over backwards to get this, but unbelievably enough, here is the coveted, mysterious, top secret interior fuse box diagram!
  5. Dec 4, 2019 at 6:45 AM
    Jmakingmecrazy
    Jmakingmecrazy New Member
    Brentwood,NH
    2019 TRD PRO Crew Max
    Magnuson supercharged
    thought i'd share this. This image is from a 2019 TRD PRO Crew Max. As i am looking for a safe location to connect power to for heated seats.. Suggestions welcomed.
  6. Feb 1, 2024 at 12:44 PM
    kpeel252
    kpeel252 New Member
    Ken
    2018 Tundra TRD
    Bed Light :)
    Thanks, everyone for the clue where the "Other" fuse box is. I wanted to share this image. Yea you'll have to get on your back to find it !.
  7. Feb 5, 2024 at 5:51 PM
    2A Dave
    2A Dave New Member
    Installing a dash cam on mine. Isn't there a way to access the fuse panel from the side of the dash board, just above the kick plate? I'm a little too banged up to be crawling around the cab on my back...lol
  8. Feb 6, 2024 at 1:04 PM
    kpeel252
    kpeel252 New Member
    Ken
    2018 Tundra TRD
    Bed Light :)
    Looking up from the fuse box, I think you can get a wire up and over to your location. I do know there is a spot for a new connection that is live. At least in mine, there is.
    Good luck.
  9. Feb 6, 2024 at 8:24 PM
    2A Dave
    2A Dave New Member
    Thanks. I was actually hoping I wouldn't have to lay down face-up to get to the fuse box. In my current physical condition I'd have to remove the driver's seat to be able to get to the fuse box. Looks like I'll be putting another one of my mechanics kids through college this year:annoyed:
  10. Feb 7, 2024 at 9:03 AM
    kpeel252
    kpeel252 New Member
    Ken
    2018 Tundra TRD
    Bed Light :)
    Yea I have a bad knee and it was painful.. yup send the kid mechanic in for the job. LOL. Make them wear PPE.. LOL :rofl:
