Furnace ignites then stops
Discussion in 'Home Improvement' started by MS22, Nov 29, 2019.
  1. Nov 29, 2019 at 9:08 PM
    MS22
    MS22 [OP] New Member
    02 Tundra 4x4
    Hey all just wondering if you might have any suggestions. I have a stage 1 furnace that gets ignition then stops. At first I was getting a pressure switch stuck closed code. I replaced pressure switch and reducer fan a couple weeks ago and all was good. Now it's doing the same thing but the board isn't flashing any codes. I replaced the flame sensor and still no go.
    Thanks much
    Mountun Goat likes this.
  2. Nov 29, 2019 at 9:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Inspect your flue for obstructions, bird nest, a bird, whatever. Test the switch if you can. Try to watch a cycle and see if it actually ignites and then turns off or see if your getting flame rollout
    landphil likes this.
  3. Nov 29, 2019 at 9:15 PM
    MS22
    02 Tundra 4x4
    Flue is clear and no flame rollout and checked the safety switches. I do get flame for a few seconds then shuts off.
  4. Nov 29, 2019 at 10:17 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Sounds like sensing rod. I know you said you changed it already though.
  5. Nov 30, 2019 at 12:08 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Try cleaning or replacing the thermo coupler. My old furnace I had to take some fine grit emery cloth to the thermos coupler every couple of years and clean off the white build up.
    Sas and Mountun Goat like this.
  6. Nov 30, 2019 at 2:15 AM
    Make sure everything inside the furnace is clean. I once had a dust bunny/lint/whatever cost me a grip of money.
    After that, I would call a professional. People die doing their own furnace/hot water heater repairs all the time. I personally know three that have...
  7. Nov 30, 2019 at 2:35 AM
    Grumpy Uncle
    Pat
    CO
    Last year around this time we had a similar problem. $836 later it was a control board and a thermostat.
  8. Nov 30, 2019 at 6:24 AM
    PowerMan81
    PowerMan81 New Member
    Nor Cal
    2019 Tundra DC SR5 4x4
    I just went through this almost exact same problem. Thought it was the flame rod, turned out to be a loose connection on the thermostat terminal strip.
  9. Nov 30, 2019 at 7:15 AM
    Freonjohn
    Freonjohn New Member
    What brand?
    Model and serial# ?
  10. Nov 30, 2019 at 8:22 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Thermocoupler. This is a very cheap easy replacement. Most likely this.
    Sas likes this.
  11. Nov 30, 2019 at 8:25 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Also if you’re mechanical room (floor) is dusty enough your furnace won’t act properly as the air intake is on the bottom. Try blowing it all out with compressed air.
  12. Nov 30, 2019 at 9:53 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I had the same problem with my furnace about 5 years ago. It slowly went from kicking out, then relighting after a couple minutes of running to lighting and almost instantly kicking off.
    I cleaned the flame sensor, added another ground wire from beside the flame sensor to the control board, no improvement.
    I called an HVAC tech, had him service /troubleshoot, seemed like a good idea, right? He called the control board since he couldn’t find anything else, but wanted way too much to replace it with no guarantee of success. They really pushed for a full replacement, which would be an expensive nightmare in my house.
    I ordered a board and a vacuum switch for the inducer fan just in case, replaced both and still the issue remained.
    Finally I took the vacuum sense hose off the switch, let it run it’s light-up cycle with the clear hose stuck in a cup of water and found the vacuum from the inducer fan was < 1” of water on a .8” of water rated switch. Teeing the line back to the switch, the actual vacuum dropped even lower with the burner lit up, tripping the vacuum switch, shutting the burner down before relighting.
    That’s when I pulled the inducer fan to find nothing wrong. Next step was flue inspection, from above it looked great. When I pulled the short, nearly horizontal pipe just above the furnace over to the main flue, I found it half-full of fine ash accumulated over many years.
    After cleaning that out, the inducer vacuum was nearly 3” of water, and problem solved.
    FrenchToasty likes this.
  13. Nov 30, 2019 at 10:15 AM
    Rubberdown
    Man. I just realized I don’t know crap about furnaces.
  14. Nov 30, 2019 at 10:35 AM
    PotentPotables
    Washington
    We had an old Carrier that was doing this. Turned out to be a control board but I wanted to know what would cause the control board to fail. After poking around, I found our heat exchanger was cracked anyway. Had to either replace the exchanger and the control board or spend about $900 more to get a new furnace with warranty. The union was offering a $400 rebate at the time making the price difference around $500 more for a new unit.
    I’m glad I didn’t just purchase and replace the control board on a failed unit.
