Fumoto valve
Discussion in '3rd Gen Tundras (2022+)' started by kelbro, Aug 22, 2023.
  1. Aug 22, 2023 at 6:17 PM
    kelbro
    kelbro [OP] New Member
    2021 1794 CrewMax 4x4 in Wind Chill Pearl
    2̶0̶2̶2̶ ̶1̶7̶9̶4̶ ̶C̶r̶e̶w̶ ̶M̶a̶x̶ ̶4̶x̶4̶ ̶w̶i̶t̶h̶ ̶A̶d̶v̶a̶n̶c̶e̶d̶ ̶P̶a̶c̶k̶a̶g̶e̶
    Which Fumoto valve for the non-hybrid TTV6?
    Thanks
  2. Aug 22, 2023 at 6:27 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
  3. Aug 22, 2023 at 6:30 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
  4. Aug 22, 2023 at 6:33 PM
    kelbro
    Thanks!
  5. Aug 22, 2023 at 6:49 PM
    TRD L Power
    TRD L Power New Member
    2023 SR5 XP TRD Off-Road Army Green
  6. Aug 22, 2023 at 7:24 PM
    4genRunner
    Southwestern MO
    2 reasons. I prefer the longer nipple on the F133N and I personally don’t see the need for adjustable position.
    Cruiserpilot, Tom976 and bulldog93 like this.
  7. Aug 22, 2023 at 9:54 PM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    My plastic lever clip retainer came off and I saw that Fumoto sells basically a spring hose clamp. I needed one immediately so I got one from Ace for $.85, great insurance if you off road at all and don’t have a skid plate covering the oil pan. I went with the short nipple valve so it didn’t stick down as much.
    vtl and graf_von_tundra like this.
  8. Aug 27, 2023 at 5:57 AM
    TRD L Power
    I was curious and wanted to see both the F103sx and F133n side by side, so I ended up grabbing both and will return the one I don’t want.
    Figured I should post an image of them for anyone else considering one or the other.
    Right now, I’m leaning towards using the F133n because it’s actually smaller and seems like it would have fewer points of failure. I’m doing my first oil change on the ‘23 at 1100 miles this weekend and will update if my mind changes while under there.
  9. Aug 27, 2023 at 6:21 AM
    Wallygator
  10. Aug 27, 2023 at 6:32 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I prefer the Fumoto because it doesn't require tools or to carry/be able to locate any additional parts to drain the oil. Last thing I need is to be across the country, need an oil change, and lol can't find the screw-in drain hose thing.
    I've got the TRD skidplate with full coverage so nothing I'll ever hit my truck with will every connect with the Fumoto, let alone jostle the lever, it's well protected. These new copper clamp things look cool, I might grab a few to see how they compare to the plastic ones!
    bulldog93 and 40man like this.
  11. Aug 27, 2023 at 6:38 AM
    Wallygator
    Yeah the Fumoto probably works just as well, I posted another option. So...You don't use a hose with the Fumoto? It wouldn't be hard to carry the screw in adapter and an 8" piece of hose on a road trip. Can fit into a sandwich bag and placed in the center console. :D
  12. Aug 27, 2023 at 6:57 AM
    MedCityMoto
    I carry a very short 6" one for ease of use, but if I lose it or some crackhead steals it out of my truck etc, I'm not stuck, just less control of the fluid flow at draining!
    Wallygator[QUOTED] likes this.
  13. Aug 27, 2023 at 7:56 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I have the valvomax and it’s very tidy.
    IMG_6537.jpg An adjustable crescent wrench will make short work of removing either drain plug in a pinch.
    bulldog93 and Wallygator like this.
  14. Aug 27, 2023 at 8:20 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    By any chance do you remember the size spring clamp you used? I’d like to pick a few up for all of my vehicles, but can’t see paying $2 a piece plus shipping from Fumoto.
    MedCityMoto likes this.
  15. Aug 27, 2023 at 9:47 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    5/8” or the next size up
  16. Aug 27, 2023 at 10:30 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I went with the Valvomax as the Fumoto has been known to strip during install/torque.
    Wallygator likes this.
  17. Aug 28, 2023 at 1:18 AM
    First I've heard of it stripping.
  18. Aug 28, 2023 at 3:46 AM
    MedCityMoto
    Gonna need a citation on this supposed knowledge there, thanks
    GODZILLA likes this.
  19. Aug 28, 2023 at 3:57 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    20 year Fumoto man here on six different vehicles. This ^^^ = ?????
  20. Aug 28, 2023 at 4:59 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I actually had a Valvomax strip during torque that I installed on my Audi Q7. I ended up having to add epoxy on the threads. <shrug> It wasn't the Valvomax that stripped per se, but the threads for the oil drain plug.
    bulldog93 likes this.
  21. Aug 28, 2023 at 5:26 AM
    Tom976
    Tom976 New Member
    Tom
    Never heard that one and I have had 6+ vehicles with Fumoto valves. I would say follow the instructions.
    I use the f133n on my truck. Nicely tucked up there. Only thing you can use is a clear hose to put on the nipple.
    That way it can drain on nice windy day without spilling a drop.
    Twin2turbo, TreeCat and GODZILLA like this.
  22. Aug 28, 2023 at 5:52 AM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    If anything is stripped it’s from over torquing.
    Fumoto has torque specs of about 15 (depending on model) which is half of the oem plug torque. And I’d say most people just tighten “good and tight” without a torque wrench. 15 pounds isn’t much.
    The valvomax lists “hand tight with a wrench” as a spec. I can see this as a problem.
    Valvomax I’d tighten to fumoto torque.
    I tried ordering the Valvomax and I can’t “click” the shopping cart.
  23. Aug 28, 2023 at 8:10 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I installed the Fumoto on my 2022 tundra and works great. Installed perfectly on my Tacoma too. Just don’t be dumb installing it
  24. Aug 28, 2023 at 11:10 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    The internet has a search function, which I used.
    I used a Fumoto on my Stinger as it has a plastic oil pan, I know how to torque.
    Thank you for your concern.
    I didn't like installing a soft brass valve in a hardened steel oil pan on the Tundra, why I went with a steel Valvomax.
    Made is USA, veteran owned.
    https://www.mavericktruckclub.com/forum/threads/fumoto-valve-fail.33318/
    Wallygator and bulldog93 like this.
  25. Aug 28, 2023 at 11:46 AM
    raylo
    raylo not so new member
    Frederick, MD
    I added a Fumoto at my last oil change. It went on like any oil pan drain plug. Put it on by feel, firm but not too much torque, same way I have done maybe 500 oil changes.
  26. Aug 28, 2023 at 3:13 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Do you have to take the skid plate off to get to the filter?
  27. Aug 28, 2023 at 3:20 PM
    raylo
    Frederick, MD
    TRD skid, yes.
  28. Aug 28, 2023 at 3:25 PM
    BoulderGT3
    Glen
    To me, because I'm under the truck screwing around with the filter anyways, the drain plug isn't a big deal. Maybe 30 seconds to remove and 30 seconds to put back in. Different when the filter is accessed via the top.
  29. Aug 28, 2023 at 3:27 PM
    raylo
    Frederick, MD
    It's still nice to take the oil straight to a storage container and not have to use a big messy oil drain pan. And then have to pour that into the storage container. Just need a smaller one for the filter.
  30. Aug 28, 2023 at 3:59 PM
    That was my reasoning for getting the Jowett Performance filter housing. Billet aluminum with a similar valve for draining it. With a bit of hose neither valve risks a mess. Ultra convenient and clean, so I moved them both over to my Taco when it replaced the Tundra.
