Fumoto Valve
Discussion in 'General Tundra Discussion' started by TXRailRoadBandit73, Apr 14, 2017.
  1. Apr 14, 2017 at 5:39 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Morning all...how many you guys use the fumoto valve? Thinking of buying do you permanently leave on???? its something I know nothing about..only asking cause last week did own oil change i have a lift n some oil got all over skid plate so i see on fumoto site even has socket to attach a tube was thinking of getting any info greatly appreciated
  2. Apr 14, 2017 at 5:46 AM
    Mike Tread lightly.
    south carolina
    I own 3... I swear by them... The tube makes it less messy but imo go for it...
  3. Apr 14, 2017 at 5:48 AM
    I own three of them as well. Will never go back to a drain plug.
  4. Apr 14, 2017 at 6:18 AM
    Thanks fellas ill b ordering one
  5. Apr 15, 2017 at 1:46 AM
    Which one shud i get??? i see several on ther website.. which do you have???
  6. Apr 15, 2017 at 1:47 AM
    Which one u got???
  7. Apr 15, 2017 at 4:07 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    TheBeast and TXMiamiFan like this.
  8. Apr 15, 2017 at 4:50 AM
    Mike Tread lightly.
    south carolina
  9. Apr 15, 2017 at 4:53 AM
  10. Apr 15, 2017 at 4:58 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Does it decrease ground clearance?
    TheBeast and ColoradoTJ like this.
  11. Apr 15, 2017 at 5:06 AM
    I never seen a problem with the Fumoto valves on Toyota trucks due to the angle of the drain on the pan and how far it the valve is still tucked up under the crossmember. Now I don't have one on my rock crawler, and if you seen my oil pan and skid plates would understand why.
    MotoTundra and dcsleeper408 like this.
  12. Apr 18, 2017 at 3:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Have one on my Tacoma. I have the nipple and like it because I can just put a 5 qt jug under and drain straight in to the jug. Only problem is the oil drains slower. I plan on taking it off before selling the Tacoma and use when I buy Tundra. On the Tacoma the skid plate protects the valve. I did not know how protected it would be on the Tundra but from what I have read it does not sound like a problem.
  13. Apr 18, 2017 at 6:21 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Something else for the list...
    1UPPER likes this.
  14. Apr 18, 2017 at 7:18 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have one. i like it. would buy again.
  15. Apr 18, 2017 at 7:20 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have one as well and love it. Just leave it in. Attached a tube every time you do an oil change.
    NewImprovedRon likes this.
  16. Apr 18, 2017 at 11:15 AM
    You have one with nipple extension tube?
  17. Apr 18, 2017 at 11:31 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I put mine on when I did my first oil change at 5k. I ran one on my last rig, too. It makes things so much cleaner, easier, and faster when doing the oil change. Also make sure you upgrade the oil filter canister to the aluminum one instead of the stock plastic one (I cracked mine early on). The Sequoias have the aluminum one and it fits the same.
    I've never had any problems with the valve itself leaking or breaking.
    MotoTundra likes this.
  18. Apr 18, 2017 at 12:06 PM
    csuviper
    Broomfield, CO
  19. Apr 18, 2017 at 12:07 PM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Just added this to my Amazon Wish List. Thank you!
  20. Apr 18, 2017 at 12:10 PM
    csuviper
    Broomfield, CO
    Pic with nipple but without the tube attached. Guess i did't get a pic with the tube attached.
    MotoTundra and AxelsHumanDad like this.
  21. Apr 18, 2017 at 12:34 PM
  22. Apr 18, 2017 at 12:35 PM
    Part number? Or where to find?
  23. Apr 18, 2017 at 5:31 PM
