Fumoto valve question
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Jan 24, 2023.
  1. Jan 24, 2023 at 12:10 PM
    eagleguy
    eagleguy [OP] New Member
  2. Jan 24, 2023 at 1:02 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    I have the F103SX and use the hose but cut it shorter
  3. Jan 24, 2023 at 2:23 PM
    AZBoatHauler
    So.Arizona
    RobertD likes this.
  4. Jan 24, 2023 at 2:32 PM
    eagleguy
  5. Jan 24, 2023 at 2:34 PM
    AZBoatHauler
    So.Arizona
    Plenty of room and still tucked up above the bottom of the skid.
    GODZILLA likes this.
  6. Jan 24, 2023 at 2:36 PM
    18" TRD Off Road Wheels
    I had the longer one with my RCI skids, and had no problems. I used the hose to prevent mess and recommend it.
    AZBoatHauler likes this.
  7. Jan 24, 2023 at 2:38 PM
    eagleguy
    What is tucked up, the hose?
  8. Jan 24, 2023 at 2:39 PM
    AZBoatHauler
    So.Arizona
    The fitting where the hose attaches - correct. You can easily reach it but it isnt likely to get smacked on the road or trail.
  9. Jan 24, 2023 at 2:40 PM
    You remove the hose and store it. The nipple stays above the skids. You'd have to have a seriously hard impact to damage it.
  10. Jan 24, 2023 at 2:44 PM
    eagleguy
    Thanks guys! No off road intended but there are 4 versions and I like the longer nipple for the hose connection.
  11. Jan 24, 2023 at 2:47 PM
    You'll love it!
  12. Jan 24, 2023 at 2:54 PM
    AZBoatHauler
    So.Arizona
  13. Jan 24, 2023 at 4:23 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Not sure which model number mine is. I have the RCI skid plates. Fumoto valve is up enough and out of the way. I think it’s well protected. I just installed mine and haven’t used it yet. Next oil change will be the 1st time using it. It looks like I won’t need a hose since skid plate has a notch cut in to give room for the oil change. D1ABF124-6B6F-4E75-91DB-4938BC705527.jpg
  14. Jan 24, 2023 at 4:27 PM
    2014 Black tundra
    2014 tundra sr5
    Also that notch in the skid plate gave enough room for the regular oil drain bolt to be removed and had no mess with the oil.
  15. Jan 24, 2023 at 4:49 PM
  16. Jan 25, 2023 at 4:45 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use a piece of hose that came with my filter drain kit and go straight into a 5 qt jug. Only problem is I have to stay under the truck for the first 3 qts and switch jugs.
    bulldog93 and AZBoatHauler like this.
  17. Jan 27, 2023 at 7:33 AM
    eagleguy
    Thanks for the info guys!
