Fumoto Valve Installation
Discussion in '1st Gen Tundras (2000-2006)' started by carpenter356, Dec 9, 2020.
  1. Dec 9, 2020 at 3:35 PM
    carpenter356
    carpenter356 [OP] New Member
    Madison
    2006 DC Limited
    tunyota, Darkness, Cruzer and 4 others like this.
  2. Dec 9, 2020 at 3:37 PM
    Outbound
    Aaron
    Northern Alberta
    I have one. I really like it. My only complaint is that it drains really slowly. It probably takes 2, maybe 3 times as long to drain. It's not a big deal for me though as I do my oil change at the same time as I do my seasonal tire swap so I'll do the 2 front tires while the oil drains.
  3. Dec 9, 2020 at 3:37 PM
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Best thing since sliced bread! I have one on my Tacoma and will be putting one on the Tundra at the first oil change.
  4. Dec 9, 2020 at 3:40 PM
    Professional Hand Model
    Hand Protectors
    Dude. That frame looks brand new or you are Feather Duster Extrodinaíre. I like the matching Yellow Zinc Bolt to compliment your Fumo Valve.
    TheBeast, Darkness and Drainbung like this.
  5. Dec 9, 2020 at 4:44 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    It's great! Forgot to put in the black lock clip.
    4wd TRD PRO likes this.
  6. Dec 9, 2020 at 6:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hated mine at first because it legitimately took nearly 90 minutes to drain. Someone said I need to do it with the engine warm. Now it drains in 5-10 and I love it. I attach a hose to the end and run it down through my skid plate into my catch pan.
    Outbound, Drainbung and FrenchToasty like this.
  7. Dec 9, 2020 at 6:18 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Absolutely love mine. :)1.jpg
    tunyota, WILLINH, TheBeast and 6 others like this.
  8. Dec 10, 2020 at 4:03 AM
    Hand Protectors
    That looks like a Spigot from a Big Box Store. Tell us more...
  9. Dec 10, 2020 at 4:35 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Some really dirty oil, too...
    AZBoatHauler and YardBird like this.
  10. Dec 10, 2020 at 5:39 AM
    carpenter356
    Madison
    2006 DC Limited
    I am more interested in that dually conversion. :yes:
  11. Dec 10, 2020 at 6:08 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Ikr. I know that vehicle is a diesel..but whenever I change my parents 2013 silverado 5.3's oil, it comes out black , even at 5k. I'm not sure if that means anything or not but the average person would assume that that's a BAD thing.
    YardBird likes this.
  12. Dec 10, 2020 at 6:31 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    I used to put them on everything I owned for the past 30 years. But I no longer change my own oil. Now just easier to get it done with the yearly state inspection. They do take a little longer to drain. Which was never a problem for me.
    But had a friend that worked at a shop. Told me some serv tech will not wait longer. They just drain part of the oil instead of waiting. And since I only put on about 4K miles a year.
    On each of my 2003 Tundra & 2003 4runner. My old oil is never dirty enough to tell the difference. I guess they do run the risk of overfilling since they have to guess. But then again, this makes it easy to drain a little back out.
    But when doing myself all the time, I always loved the things since they came out.
  13. Dec 10, 2020 at 8:11 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I installed one when I did my last oil change which was the first one I have done on the Tundra now that the ToyotaCare is up. Looking forward to testing it out this Spring and not dumping a quart of oil on top of my skid plate like last time :)
    TheBeast and YardBird like this.
  14. Dec 10, 2020 at 8:13 AM
    Outbound
    Aaron
    Northern Alberta
    Having the oil fill cap off helps too.
  15. Dec 10, 2020 at 8:14 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I either crack the cap or pull the dipstick slightly
  16. Dec 10, 2020 at 8:34 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Got a fumoto on 3 of my 5 vehicles, yes drains slower, but remember to remove/loosen oil filler cap first, that helps speed things up considerably.
    Ok, where is the Hose? I put one on my vehicles and leave it in place, just coil it up there where it won't fall, no hunting at oil change time, its right there! Much less of a mess....Luck all.
  17. Dec 10, 2020 at 8:38 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    What size hose can fit on the nipple?
  18. Dec 10, 2020 at 9:32 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Have Fumotos on all my vehicles. Only way to go.
    I put the front of the vehicle up on ramps, remove the filler cap, open the Fumoto and let it rip.
    Haaaaaappy Fumoto camper.
  19. Dec 10, 2020 at 10:06 AM
    Pucks18
    Once im 45-50 years old I'll put one on my truck;)
    Johnsonman and des2mtn like this.
  20. Dec 10, 2020 at 10:29 AM
    Garand
    Garand New Member
    2024 TRD OR Limited DC
    285/65R20
  21. Dec 10, 2020 at 10:36 AM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
  22. Dec 10, 2020 at 4:28 PM
    glowblue
    VA
  23. Dec 10, 2020 at 4:34 PM
    Hand Protectors
    So stoked. They also sell this. A perfect Hand Model Gift for those special others in my life.
    Drainbung likes this.
  24. Dec 10, 2020 at 4:37 PM
    FrenchToasty
    Mo
    Bone stock
    I love how their disposable funnel is more expensive than a plastic(disposable) funnel
  25. Dec 10, 2020 at 4:41 PM
    Hand Protectors
    All proceeds go to Saving The Paper Straws Foundation. I remember using rolled up newspaper when I first started changing oil back in 1947.
  26. Dec 10, 2020 at 4:46 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Was waiting for someone to state this before I got to the end of the thread and did so myself...
    Tundra2 and Outbound[QUOTED] like this.
  27. Dec 10, 2020 at 5:19 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Put one of those on my wife’s Yukon. I really like it. Built in redundancy. Some have said the washer leaks, but I haven’t had any problems.
  28. Dec 11, 2020 at 5:59 AM
    Pucks18
    I just use my Jean pockets cause I'm absolutely disgusting
  29. Dec 11, 2020 at 6:55 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    FrenchToasty likes this.
  30. Dec 11, 2020 at 7:12 PM
    70fj4045
    70fj4045 New Member
    Carl
    Connecticut
    2019 White Trunda TRD PRO
    Driver side grab handle, AMP Power steps, Front window tints, TRD Front & Rear Sway Bars, rear bumper step,TruXedo Tonneau cover.
    I have both drain valve and drain hose, works great, plus I drain right into a 2 1/2 gal jug cap it and done, no mess....
    Johnsonman and carpenter356[OP] like this.
