Full tank mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by BRP479, Sep 8, 2021.
  1. Sep 8, 2021 at 3:22 PM
    BRP479
    BRP479 [OP] New Member
    Ricky
    Rogers,AR
    I tried to do a search but no luck.
    my full tank mileage shows 300 and it use to show 330. I’ve changed a battery since then so I’ve removed the terminals and it didn’t reset.
    Has this happened to anyone else?
  2. Sep 8, 2021 at 3:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    need more info/explanation please. Not sure what your question/issue is.
  3. Sep 8, 2021 at 3:29 PM
    BRP479
    Ricky
    Rogers,AR
    My full tank after fill up shows 30 miles less than it use to. Can this be reset? If not, did I really lose 30 miles? Would a fuel cleaner help or is my tank only getting 300 miles now.
    Truck has the standard tank 26? Not 38 gal
  4. Sep 8, 2021 at 3:36 PM
    frichco228
    The truck "learns" to estimate range based on your diving and fuel use. And yes, remove the battery cable for about 20-30 minutes and it may reset and begin "learning" all over. When you do the truck will probably estimate range higher/longer than before, and it will gradually drop back to what the truck thinks the range is based on how YOU drive.
    Nic146 and Cpl_Punishment like this.
  5. Sep 8, 2021 at 3:38 PM
    frichco228
  6. Sep 8, 2021 at 3:42 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like you're getting less mpg than you used to
  7. Sep 8, 2021 at 3:46 PM
    BRP479
    Ricky
    Rogers,AR
  8. Sep 8, 2021 at 5:13 PM
    If you changed wheels and tires, that will throw it off too. Everything that the truck shows is just an estimate based on driving patterns.
    Nic146 likes this.
  9. Sep 9, 2021 at 10:27 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    you should see how it changes when you put 6lbs of forced induction on it! not pretty.
    I shall call my truck the Valdeez.
    Nic146 likes this.
  10. Sep 9, 2021 at 10:39 AM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    +2 to this.
    I would argue that estimated range on these trucks is pretty much worthless if you have any fluctuations in your driving. Maybe if you drive the same roads back and forth every day without change, it may be somewhat accurate.
    That said, it takes so long to calibrate that it just doesn’t keep up.
    I don’t think mine has ever been accurate within 50 miles since I purchased my Tundra.
  11. Sep 9, 2021 at 10:39 AM
    TowingTundra
    TowingTundra New Member
    2017 Tundra Grey Crewmax 4x4
    You should see how it changes when you are towing 30' trailer and a 4 seater SxS. :rofl::rofl::rofl:
    Nic146 likes this.
