Full Range Speakers In Doors?
Discussion in 'Audio & Video' started by atc250r, Mar 29, 2025.
  1. Mar 29, 2025 at 7:13 AM
    atc250r
    atc250r [OP] New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    I've got a 2020 double cab SR5 TRD OR non-JBL and have the speakers I pulled out of my Taco before trading it in which it appears will fit the Tundra. I know the front doors are the woofers/mids and the tweeters are in the dash. Will there be any issues if I put the full range speakers in the doors?
  2. Mar 29, 2025 at 2:59 PM
    Snert
    Snert New Member
    2021 SR5
    In theory no, are the taco speakers stamped on the back with their ohm rating and power handling? Your door woofers are 35w and 2 ohm, only thing is if they’re 4 ohm they might be a good bit more quiet.
    atc250r[QUOTED][OP] likes this.
  3. Mar 29, 2025 at 7:24 PM
    atc250r
    Yeah, they're 4 ohm Kicker CS. From the videos I've seen on YouTube the crossover is in the speaker so I'll get full range out if them.
  4. Mar 30, 2025 at 1:04 PM
    Snert
    Snert New Member
    2021 SR5
    Your factory speakers in the tundra are 2 ohms and 35w, meaning your factory amp maybe does around 20w at 4 ohms. Depending on the sensitivity of those Kicker speakers, they’re probably going to be more quiet than the factory ones.
    By full range do you mean they’re a coaxial speaker with a tweeter mounted in the middle? If that’s the case the crossover on the speaker is acting as a bass blocker to the tweeter.
    Worst thing that’ll happen is they won’t be as loud.
  5. Mar 30, 2025 at 2:46 PM
    atc250r
    Yeah, I'm not so worried about loud as about sounding better. I just wasn't sure if the input to the door speakers was a full range or if the highs were filtered out but it sounds like they're not.
