Full dash light up
Discussion in '2nd Gen Tundras (2007-2013)' started by Dennisk90, Aug 10, 2024.
  1. Aug 10, 2024 at 3:25 PM
    Dennisk90
    Dennisk90 [OP] New Member
    I have a 08 5.7l V8 tundra and sometime when I start it the whole dash is lit up. VSC, Check engine, traction control, 4lo. No idea what's cause the dash to be a Christmas tree. Any help would be greatly appreciated.
  2. Aug 10, 2024 at 3:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Get the codes and post them all here, to start . . .
  3. Aug 10, 2024 at 4:40 PM
    Dennisk90
    Hooked up the odb2 and didn't pull codes, just reset them
  4. Aug 10, 2024 at 6:41 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    This is just on start up? Initial key ON? Take a pic
  5. Aug 10, 2024 at 6:43 PM
    Dennisk90
    Initial key turn on and after running
  6. Aug 10, 2024 at 6:43 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    So lights aren’t extinguishing? Is the key rolling back properly on the spring after start?
  7. Aug 11, 2024 at 5:55 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Those code are needed to tell you what the ECU is indicating is wrong. Use the truck as normal until the codes set again, then read them and share them here.
