Fueling problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ja102003, Sep 21, 2018.
  1. Sep 21, 2018 at 10:21 PM
    Ja102003
    Ja102003 [OP] New Member
    Jonathan
    2016 Toyota Tundra
    Bullydog tuner & cold air intake
    Hey guys I have a 2016 tundra sr5. I have a problem fueling up my truck, every time I go to put fuel the pump shut off as soon as I start to put fuel. I’ve also disconnected the vent line coming off the gas tank that goes to the charcoal canister and it still doesn’t work. If someone could help me out it would be great, thanks
    Y0TA PR0 likes this.
  2. Sep 21, 2018 at 10:46 PM
    Hey Jonathan, welcome to the site.
    With having a 16, this should be covered under the emissions warranty of your truck.
    Anyway, you could have a kinked line, bad evap fill vent valve, or tank vent.
  3. Sep 21, 2018 at 11:02 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    I had the same issue.
    I took it to the dealer and they ended up replacing my entire gas tank.
    GNTundra and ColoradoTJ like this.
  4. Sep 21, 2018 at 11:03 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
  5. Sep 21, 2018 at 11:07 PM
  6. Sep 21, 2018 at 11:16 PM
    Ja102003
    Jonathan
    2016 Toyota Tundra
    ColoradoTJ- I’m thinking it might be the evap vent fill valve and having that bullydog doesn’t it void my warranty?
  7. Sep 21, 2018 at 11:17 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Luckily they took care of it under warranty.
  8. Sep 21, 2018 at 11:21 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Mine has the same problem too!!! It’s at the dealership right now ! Under warranty thankfully !
    ColoradoTJ likes this.
  9. Sep 21, 2018 at 11:25 PM
    Not sure how the bully dog would void your evap vent line. Might void other things like the ECM, but they would have to prove that the BD did that.
    The dealership tried for a second to blame my front diff growl on my Bilstein 6112 on the lowest setting (.75" lift), and I smashed that pretty quickly showing them the TRD PRO has a 2" lift and gave them the TSB on the needle bearing that is common to fail on Toyota 4wd front diffs. I pushed back and they backed down pretty quickly.
  10. Sep 21, 2018 at 11:27 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  11. Sep 21, 2018 at 11:29 PM
    You forgot the hoser or Eh.
  12. Sep 21, 2018 at 11:33 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I believe he’s having trouble hosing his fuel tank eh!
    Ostrich, landphil, Watt maker and 3 others like this.
  13. Sep 21, 2018 at 11:37 PM
    Perfect!
    Y0TA PR0[QUOTED] likes this.
  14. Sep 21, 2018 at 11:39 PM
    Ja102003
    Jonathan
    2016 Toyota Tundra
    Thanks bud I’ll give it a try and take her in
  15. Sep 21, 2018 at 11:41 PM
    Keep us posted on how it goes. Also, take the BD program off. No reason to poke the bear, so to speak.
    GNTundra and Watt maker like this.
  16. Sep 21, 2018 at 11:41 PM
    Ja102003
    Jonathan
    2016 Toyota Tundra
    What’s a hoser/Eh
  17. Sep 21, 2018 at 11:42 PM
    Ja102003
    Jonathan
    2016 Toyota Tundra
    Will do
  18. Sep 21, 2018 at 11:51 PM
    He is one of our brothers up north in Canada.
    This will explain a lot...Canadians love to party, procreate, and make great beer.
  19. Sep 30, 2018 at 2:37 PM
    Tundranator
    Tundranator New Member
    Shawn
    2016 Tundra TRD
    Im having th same issues ja102003! Thought I’d check this forum and it appears your having the same problem. Since the dealer repairs have you had any more issues?
    GNTundra likes this.
  20. Sep 30, 2018 at 3:36 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  21. Sep 30, 2018 at 5:40 PM
    anthonygan
    2017 Cement TRD PRO
    The dealership fixed mine by giving me a new tank! They said something about there being baffles in or on the gas tank that sometimes get stuck! So they just replaced the whole tank
  22. Oct 1, 2018 at 9:57 AM
    Tundranator
    Shawn
    2016 Tundra TRD
    In the shop now waiting on their diagnostic check. I will update once I get the word on what they find.
    15whtrd likes this.
  23. Oct 2, 2018 at 5:22 AM
    Tundranator
    Shawn
    2016 Tundra TRD
    Update! After exceeding the 36k factory warranty I have been told the repairs would exceed 2k to replace the fuel tank. They apparently have found the baffles blocking the vent? I’m heading to the dealer today to talk about the pricing, warranty, and any recalls pertaining to this frequent problem amongst allot of Tundra owners accross the US.
  24. Dec 4, 2018 at 9:33 PM
    zebian2
    zebian2 New Member
    Jamy
    Any Updates?
    Thank you
  25. Mar 12, 2019 at 4:21 AM
    Shoewho
    Shoewho New Member
    Lenard
    2018 tundra crew max
    Train horns, sound system amp and speakers, console safe
    Same problem here tank wont accept fuel. New tank on order
  26. Mar 12, 2019 at 5:51 AM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I've had this exact same issue. Turns out the rollover valve was wedged shut by a broken baffle (according to tech I talked to). Whole tank was replaced under extended warranty & 42k miles. Guy also told me he sees this about 1-2x a year.
  27. Mar 12, 2019 at 8:27 AM
    zebian2
    zebian2 New Member
    Jamy
    Was your truck been rear ended at any points?
    Let me know
  28. Aug 19, 2019 at 1:12 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    I’m having the same issue now. 2 months out of warranty. What ended up happening?
  29. Dec 7, 2020 at 6:36 AM
    hellis1
    hellis1 New Member
    Herb
    I'm trying to connect my Gasoline rated Transfer Tank into my fuel system. Any suggestions?
