Fueling Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by zebian2, Jan 5, 2019.
  1. Jan 5, 2019 at 6:19 PM
    zebian2
    zebian2 [OP] New Member
    Jamy
    2014 1794 with 67k miles.
    Fuel light came on with less than 1/4 tank.
    Tried to fuel and it won’t take more than $30 before the nozzle stops.
    I managed to add 2 more gallons.
    Now the fuel gauge is showing that the tank is almost full ( needle is between 3/4 and full)
    It is strange.
    Could it be the sending unit?
    Last time I checked my hoses and none is kinked or pinched.
    Your input in much appreciated
    Thank you
  2. Jan 5, 2019 at 7:17 PM
    Can be, yes
    Do u typically top off when u fuel?
  3. Jan 5, 2019 at 7:30 PM
    zebian2
    Jamy
  4. Jan 5, 2019 at 7:31 PM
    Have you tried a different pump?
  5. Jan 5, 2019 at 7:33 PM
    zebian2
    Jamy
    The truck is new to me
    1st time I was fueling I was only able to put about $45.00 worth of fuel
    Changed 2 gas station to no good.
  6. Jan 5, 2019 at 7:34 PM
    zebian2
    Jamy
    I’m hopping that I won’t need to pull the tank off
  7. Jan 5, 2019 at 7:35 PM
    zebian2
    Jamy
    I’m leaning towards the conclusion that the sending unit is at fault.
  8. Jan 5, 2019 at 7:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Next time it gets down to the sending unit saying it’s at a quarter tank, go tap on the side of the tank to see if it sounds low.
  9. Jan 5, 2019 at 7:44 PM
    zebian2
    Jamy
    Great idea
    I was thinking about Tapping on the tank tomorrow morning to see if it’s actually full.
    Thank you
    15whtrd likes this.
  10. Jan 5, 2019 at 7:45 PM
    Yeah, try a different pump or fuel at a different angle.
  11. Jan 5, 2019 at 7:50 PM
    zebian2
    Jamy
    Definitely
  12. Jan 16, 2019 at 3:36 PM
    zebian2
    Jamy
    What do I need to be looking at when it comes to the charcoal canister for the fuel tank?
    All ports seems open when I blow air through themF119A4FB-B2CD-4F78-8F94-FC62D0E3E58B.jpg
  13. Jan 17, 2019 at 5:12 PM
    Nmanning556
    Nmanning556 New Member
    VA
    2015 Crewmax SR5 4x4
    When you remove the gas cap, does vapor escape and hiss out?
  14. Jan 17, 2019 at 5:21 PM
    zebian2
    Jamy
  15. Jan 17, 2019 at 5:46 PM
    Nmanning556
    VA
    You may have a problem with the fuel cut off float valve in the tank. According to repair manual, it necessitates replacement of the tank, as the valve is built in.
    I'd take it to the dealer to diagnose and confirm, there's a test they can do to manually pressurize the tank and check to see that the valve is operating ok or not.
  16. Jan 17, 2019 at 5:47 PM
    Nmanning556
    VA
  17. Jan 18, 2019 at 8:31 AM
    zebian2
    Jamy
    Interesting
    I’ll look into that
    Meanwhile do you think I can upgrade to the 38 gallons?
    Thank you
    15whtrd likes this.
  18. Jan 18, 2019 at 8:34 AM
    Nmanning556
    VA
    I don't personally know the compatibility or what's needed to upgrade tanks ( I'm on the Lexus side of things ), hopefully someone else can answer
  19. Jan 18, 2019 at 8:51 AM
    zebian2
    Jamy
    Thank you for your help
    The information you posted regarding the cut-off valve is in the service manual?
  20. Jan 18, 2019 at 9:31 AM
    Nmanning556
    VA
    Yes that's from the factory manual for your year.
  21. Jan 18, 2019 at 9:39 AM
    zebian2
    Jamy
    Thank you
  22. Jan 18, 2019 at 9:49 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
  23. Jan 18, 2019 at 10:39 AM
    zebian2
    Jamy
    That is an amazing detailed write up.
    A lot of credit to the writer.
    Much appreciated
