Fuel wheels/balancing issue
Discussion in 'Wheels & Tires' started by BTBAKER, May 1, 2018.
  1. May 1, 2018 at 7:12 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I will try to make a pretty long story shorter. I now have Fuel Vapor wheels paired with Nitto Ridge Grapplers.
    I have had them balanced 3 times and road forced once and every time they add more weight and then tell me they are perfect.
    I STILL get a steering wheel wobble at 55-65 and it bugs the hell out of me.
    So, a couple questions..
    Would you guys put up with a little wobble?
    And, they will work with me so what is a high quality wheel you guys would recommend? And should I try new tires and wheels or swap one out at a time?
    The manager of this Discount did not seem overly impressed with Fuel quality when I picked them.
    What’s your thoughts?
    Truck has 11,000 on it. 6112/5160 setup at 1.9.
  2. May 1, 2018 at 7:21 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Wow, Vapors were my first choice, I ended up liking the Method Mesh’s more. I heard that was a problem with KO2’s.
    It’s definitely the wheels, or tires? Bad QC if it was the wheels. Curious also because my NRG’s are fairly new and still driving straight.
  3. May 1, 2018 at 7:25 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I think it’s the wheels. I had Black Rhinos first and I don’t recall this issue. I may look at the Methods.
  4. May 1, 2018 at 9:19 AM
    I have two sets of fuel wheels never had a problem.
  5. May 1, 2018 at 9:42 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Right on! I’m sure a bad set can come out from any make. It’s possibly the Nittos as well.
  6. May 1, 2018 at 10:07 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, you can't live with a steering wheel wobble. That'll drive you crazy. I would try going somewhere else to balance. If they're adding weight every time they balance, they obviously didn't balance correctly the previous time. And I think there's a higher chance the tires are the problem rather than the wheels. Are these tires new?
  7. May 1, 2018 at 10:20 AM
    Toytec does balancing and such. Just an FYI.
  8. May 1, 2018 at 10:23 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Are these wheels hub-centric or lug-centric?
    BTBAKER[OP] likes this.
  9. May 1, 2018 at 10:34 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thanks bro, tires are new. 3000 maybe.
    Prostar 190 likes this.
  10. May 1, 2018 at 10:34 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    They are hub centric for the Tundra.
    NCinCO and Prostar 190 like this.
  11. May 1, 2018 at 10:34 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I’m here now. They now want to rotate the tire 180 on the wheel to see if that helps.
  12. May 1, 2018 at 10:46 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    They believe if anything it’s the tire. They are suggesting if it doesn’t go away to try another tire. They recommend the Nitto Tera G2
  13. May 1, 2018 at 10:53 AM
    I had those. Good tires, but just werent aggressive enough to the eye.
  14. May 1, 2018 at 11:04 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Yep, he showed them to me. They won’t look nearly as good as the RG. What other options would you suggest?
    I’m hoping a 180 on the tires do the trick.
  15. May 1, 2018 at 11:31 AM
    MT or AT?
  16. May 1, 2018 at 11:43 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
  17. May 1, 2018 at 6:32 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    I have the toyo at2 extreme on mine and I love them. They are on fuel wheels and everything is smooth. 20180223_162630.jpg
  18. May 1, 2018 at 7:07 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Right on! I like the Fuels. I just want to eliminate the wobble. I’m going to request a tire swap if it’s still there.
  19. May 1, 2018 at 8:44 PM
    Muleycrazy13
    Buckeye, AZ
    If u swap tires consider these toyos!
  20. May 1, 2018 at 8:53 PM
    Rica25
    Ricardo
    Tulare
    I had same issue until they said it was 2 defective tires and they gave me 450 dollar credit to get what ever I wanted
  21. May 2, 2018 at 3:01 AM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    what is your wheel and tire setup? lift/leveling?
  22. May 2, 2018 at 4:59 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    That won’t work for me. Brand new tires and they can’t get them to ride true? If they even try to get me to pull out my wallet they are in for a long day! Haha
  23. May 2, 2018 at 5:28 AM
    boostedtrdpro likes this.
  24. May 2, 2018 at 5:40 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Sounds like a tire issue.
    I have the Toyo AT2 Xtreme and absolutely love them. Would buy again in a heartbeat. I have 25,000 miles on mine and doesn’t even look like I’m half way through the life of the tire. Great wet traction too.
  25. May 2, 2018 at 6:01 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Fuel wheels and 275/70/18 RG’s here....zero issues with wobble....
  26. May 2, 2018 at 6:39 AM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    Tundras are very sensitive to change. I had the same problem but it didn’t happen right away. Had the wheels/tires on for about a year before it started to wobble. Tried everything we possibly could then gave up. I finally did the Coachbuilder steering kit and wobble completely went away. Truck had 15k miles so I never thought in a million years the tie rods would have been bad. I’m guessing these stock tie rods coupled with a lift and bigger tires aren’t a good match.
  27. May 2, 2018 at 8:47 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    I have fuel hostage with cooper atp 275/70R18 and I do get some wooble too truck has 19900 miles when I swapped out to this new set last week.
  28. May 2, 2018 at 8:55 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    So your tie rods were bad? This is good info! Did you install that kit?
    LEKS[QUOTED] likes this.
  29. May 2, 2018 at 10:58 AM
    LEKS
    Makaha
    Yes. Very easy to install, you may need an alignment after.
    BTBAKER[QUOTED][OP] likes this.
  30. May 2, 2018 at 12:53 PM
    Muleycrazy13
    Buckeye, AZ
    Bilstein 6112s top setting with 5160s in rear and Toytec shackles max setting. Tires are 295/70r18 Toyo AT2 xtreme and wheels are Fuel Mavericks +20 offset.
