Fuel tank "upgrade"
Discussion in '1st Gen Tundras (2000-2006)' started by dropindeuces, Mar 29, 2021.
  1. Mar 29, 2021 at 12:13 AM
    dropindeuces
    dropindeuces [OP] New Member
    I was just curious after tracking my fuel consumption from full tank to empty (~320 miles). Has anyone thought or actually tried to expand the existing tank or borrowed one from another car to fit it? I am legitimately curious because it would be awesome to lengthen my travel range without having to carry soo much extra fuel or stop and fuel up as often. Just curious :)
  2. Mar 29, 2021 at 12:18 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    No aftermarket tanks I know of, but an auxiliary tank could easily fit where the spare goes.. but then unless you have a bumper with a swing out tire carrier, you’d have to keep your spare in the bed
    KarmaKannon likes this.
  3. Mar 29, 2021 at 12:31 AM
    dropindeuces
    I never thought about replacing the spare tire area with a aux tank, thats an awesome idea! Has anyone done this or attempted? I really want to know. I have no issues with throwing my spare in my bed, I'll just strap it down to the side or where ever. I'll still carry spare fuel and water but having that extra travel range is pretty dope. :D
  4. Mar 29, 2021 at 3:30 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Same concept I had been considering but for holding water was to replace the spare as stated above. Bronco 2 tanks are popular with ranger guys because they fit where the spare tire goes on those trucks. Something like that wouldn't be too hard to find.
    I'm just guessing here, but you'd probably just use the spare tank to feed into the main tank that way you'd only need something like a simple inline fuel pump like a cheap aitex e2000. That's the standard inline pump for many vehicles including the b2 if I recall. Once again I'm just guessing here. Still seems like a reserve tank with a transfer pump to the main tank seems easy enough.
    Another option is a cheap racing style fuel cell in the bed of the truck or with some fab work down through the bed. Pretty common stuff with desert style prerunners. Jegs and summit had modestly priced cells with internal bladders when I was more into that stuff.
    Darkness and shawn474 like this.
  5. Mar 29, 2021 at 5:40 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
  6. Mar 29, 2021 at 6:08 AM
    Professional Hand Model
    Hand Protectors
    This is the route I’d go if needed. Your concept takes less valuable room under with the spare which is a rearranging the chairs idea. Your idea could also expand to a longer tank and be used on both sides or just behind the cab.
  7. Mar 29, 2021 at 4:34 PM
    Dr.Nut
    Dr.Nut New Member
    2011 Tundra CrewMax 5.7L
    That looks like a good route for an aux tank! My uncle got this 2002 Tundra and wanting to have an aux tank as well. We'll just finish installing the new of tires from 4Wheelonline this week and we'll consider that.
  8. Mar 30, 2021 at 2:02 PM
    Hand Protectors
    Anyone here ever considered buying a used Tundra tank and enlarging it?
    dropindeuces[OP] likes this.
  9. Mar 30, 2021 at 2:34 PM
    Casper421
    In the woods
    06 DC
    Darkness likes this.
  10. Mar 30, 2021 at 2:49 PM
    Hand Protectors
    They make this Gas Tank Stretcher. Sold at Harbor Freight.
    whodatschrome and abcinv like this.
  11. Mar 30, 2021 at 2:53 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
  12. Mar 30, 2021 at 2:55 PM
    Hand Protectors
  13. Mar 30, 2021 at 2:58 PM
    eick
    eick New Member
    There’s some cheaper versions out there maybe under 1k.
    Or roll your own? Just a bunch of Jerry cans with hoses running down doesn’t convey confidence in anyone’s safety though
  14. Mar 30, 2021 at 3:12 PM
    Casper421
    In the woods
    06 DC
    Their bolt stretchers work very well!
  15. Mar 31, 2021 at 12:11 AM
    empty_lord
    05 rollover special
    time to make some calls and find a company willing to make us larger tanks?
    honestly i'd be happy with like an extra 5 gallons.. a jerry can will manage that..
  16. Mar 31, 2021 at 12:12 AM
    empty_lord
    05 rollover special
    speedtre, daveeasa and Tundra2 like this.
  17. Mar 31, 2021 at 9:00 AM
    speedtre
    speedtre New Member
    Inland Northwest
  18. Mar 31, 2021 at 9:01 AM
    daveeasa
    David
    Group buy! :)
    speedtre likes this.
  19. Mar 31, 2021 at 9:51 AM
    empty_lord
    05 rollover special
    I’d be in for a bigger tank if it was less than 1000 and used the factory sender. 30-35 gal would be great
  20. Mar 31, 2021 at 9:53 AM
    30 gallon tank would be great. I could probably get 450 or so miles outta that. Lucky to get 350 now.
  21. Jul 14, 2021 at 9:40 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Aren't our tanks 26 as is? I would pay some pretty decent money for a bolt in 35-40 gallon tank. I would not go through the trouble for less than 10 gallons. I think @shoe07 has this problom solved on a budget. My 4runner got the same 10-11 mpg towing in the Ozarks. The tank on those is about 15 and comfortable range is to use about 130. The Tundra feels like it doubled my capacity.
    https://longrangeamerica.com/shop-tanks/
  22. Jul 14, 2021 at 10:13 AM
    Yeah, 30 useable gallons. Would likely have to be at least a 34 gallon tank.
    onesojourner likes this.
  23. Jul 14, 2021 at 11:12 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  24. Nov 30, 2023 at 2:02 PM
    dan_osms.io
    dan_osms.io Milana Vayntrub...
    NorVA
    2020 Tundra Ltd w/ TRD, 2003 Honda S2000 (NASA)
    Retrax XR, Yakima Overhaul HD w/ 78" Yak Crossbar, NatureNest RTT, WolfBox G850, Halolock Phone Kit, ICS DashMount
  25. Dec 1, 2023 at 3:22 AM
    shoe07
    shoe07 New Member
    Ohio
    That tank is for 2nd Gen's
    dan_osms.io likes this.
  26. Dec 1, 2023 at 5:29 AM
  27. Dec 1, 2023 at 7:36 AM
    dan_osms.io
    NorVA
    @shoe07 Years covered seem to stretch between Fits: 2007-21
  28. Dec 1, 2023 at 8:42 AM
    shoe07
    shoe07 New Member
    Ohio
    correct, 2nd gen trucks started in 2007 and ran through 2021. 1st gens were 2000-2006. They are quite different. . . . .
  29. Dec 1, 2023 at 9:03 AM
    dan_osms.io
    NorVA
    Yep, wanted to seek someone non-supercharged to seek what the total DTE even with the unused fuel to keep the pump submerged.
  30. Dec 1, 2023 at 9:09 AM
    shoe07
    shoe07 New Member
    Ohio
    Ah, I was confused, I didn't see that you own a 2020. I was thinking you were trying to fit this tank in a 1st gen, as you are posting in a 1st gen thread, you may receive better assistance in the 2 or 2.5 gen area. . .
