Fuel Tank Skid Plate Torque
Discussion in '3rd Gen Tundras (2022+)' started by Sooks569, Mar 5, 2024.
  1. Mar 5, 2024 at 1:13 PM
    Sooks569
    Sooks569 [OP] New Member
    I'm looking to replace the plastic OEM fuel tank skid plate with an RCI steel skid plate. What is the torque spec on the nuts for securing the tanks strap studs to the plate. RCI said it should be 28 FT-LBS, but wanted to verify. 2024 Tundra Platinum w/Off Road Package
  2. Mar 5, 2024 at 1:54 PM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    US bolts with tension approximately 70% of yield strength. The values are for slightly lubricated bolts. For dry bolts increase the torques with approximately 30%.
    Aproximation formula:
    The relation between applied torque and axial force - or load - in a bolt can be calculated in this general equation as
    T = K F d (1 - l/100) (1)
    where
    T = wrench torque (Nm, lbf ft)
    K = constant that depends on the bolt material and size
    d = nominal bolt diameter (m, ft)
    F = axial bolt force (N, lbf)
    l = lubrication factor (%)
    Typical values for K with mild-steel bolts in range 1/4" to 1":
    • normal dry: K = 0.2
    • nonplated black finish: K = 0.3
    • zinc-plated: K = 0.2
    • slightly lubricated: K = 0.18
    • cadmium-plated: K = 0.16
    So verify your bolt grade and diameter. More than likely RCI is providing the correct torque. Welcome to the forums.
  3. Mar 5, 2024 at 2:19 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    and all the bolts on a tundra are metric.....
  4. Mar 5, 2024 at 2:26 PM
    mayan
    Mayan
    DFW
    Most American vendors making aftermarket parts use US bolts but I agree some of the bolts that directly attach to the frame rails will be metric the pdf has all the info to calculate torques on metric bolts.
  5. Mar 5, 2024 at 2:42 PM
    teab
    Ty
    Denver
    The bolt its probably a m10 or m12 so torque it to 42 ft-lb's or 73 ft-lb but that table is for 85% of proof load in the table, so we have to divide by 0.85 to get to yield and then multiply by 0.7 to get to the dry bolt recommend torque.... Literally was using these equations checking a tensioning profile for a wind load acting on a geomembrane liner the other day, but would never choose to answer a "What torque should I tighten the bolts on my truck to"....most people aren't engineers or engineer minded so maybe equations aren't that helpful?? IDK but hey its an answer I guess. Bottom line is follow the Toyota manufacturer recommendations is correct answer here. 28ft-lb is probably the right answer here. I mean the torque for Toyota lugnuts for aluminum wheels is 97 ft-lb...I mean the torque to get to the lug's yield is higher but that doesn't' mean I'm going to torque it to that....I'm going to go off what the Toyota engineers recommend it should be torqued to. Then there is the whole accuracy of torque as a measure of tightness not really being accurate but we won't jump down that rabbit hole.
    mayan[QUOTED] likes this.
  6. Mar 5, 2024 at 2:47 PM
    teab
    Ty
    Denver
    also......
    tundznoff, mayan and Mattedfred like this.
  7. Mar 5, 2024 at 3:27 PM
    Sooks569
    There’s no bolt per-se, it’s a stud that’s installed on the tank “strap”, I’m torquing the nut and it’s an M8 Nyloc nut.
  8. Mar 5, 2024 at 6:16 PM
    teab
    Ty
    Denver
    Follow what RCI says and you'll be good.
  9. Mar 5, 2024 at 9:02 PM
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    This is impressive, I feel smarter now
    mayan[QUOTED] and teab like this.
  10. Mar 6, 2024 at 6:12 AM
    mayan
    Mayan
    DFW
    Fastener torque is very interesting and difficult topic and varies widely in different fields these are just approximations. Some can spend their entire life like some of our ancestors did researching and debating this topic. I won't lol I just like bolts or anything with threads it's the core of my job and I find it simple yet not so simple.
    We should all feel smarter everday we wake up or we're doing something wrong lol.
