Fuel Tank size and miles to empty
Discussion in 'Performance and Tuning' started by LaTechDoc, Sep 15, 2021.
  1. Sep 15, 2021 at 6:15 AM
    LaTechDoc
    LaTechDoc [OP] New Member
    I am a new Tundra owner (April 2021 with SR5 and TRD packages) and the sticker says it should have a 38 gallon fuel tank. I have driven it down to where the computer says there is only 15 miles to empty and when I fill it, the maximum I have every filled it was about 30 gallons. I brought it to the dealer for the 10,000 mile service and asked them to check it and they are saying it has the 38 gallon tank (they showed me a picture, not that I can tell the difference). Thoughts on why the computer is not giving me the correct miles to empty? Is there a reserve tank that is not computed? There should be at least 115 miles or more left to drive. Any experience with this or wisdom would be helpful. Thank you.
    BTW, This is the first truck I have ever owned, and I freaking love it!
    AircareTundra likes this.
  2. Sep 15, 2021 at 6:16 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  3. Sep 15, 2021 at 6:18 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Welcome! And you do actually have a 38 gallon tank, it's just the way the tank is designed, there is always 7-8 gallons in the tank that are not part of your mileage computation. This is due to needing to have the fuel pump submerged in the gas. You can run it below the 0 left to empty, but that's only if you're in a pinch as it's not good for the fuel pump. Enjoy the truck! I've had mine for going on 2 years now and I love it.
    Buildn, Saltyhero13, 15whtrd and 2 others like this.
  4. Sep 15, 2021 at 6:19 AM
    PixelPusher
    PixelPusher New Member
    New Hampshire
    2020 Tundra Limited, Super White
  5. Sep 15, 2021 at 6:31 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    As stated above is not correct about the fuel pump. Fuel going thru the pump cools it, this was debunked a long time ago. Run the tank as low as u want.
  6. Sep 15, 2021 at 7:26 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    This is true. Older exposed pumps would need more fuel in the tank to cool it but most modern pumps are already encased in a plastic housing that is constantly full of fuel. It’s just a matter of programming. The gauge only accounts for 30-32 gallons.
  7. Sep 15, 2021 at 7:57 AM
    LaTechDoc
    Thank you all for the information. So the bottom line, we can just drive it past empty, but beware on how long. I did read somewhere that this has less to do with the pump and more to do with the pressure. I'm no car guy, so not sure what this means. This info, however, relieves my concern that I did not get the correct tank from the factory.
  8. Sep 16, 2021 at 8:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yes, you have conservatively 50 miles of range once the gas light comes on, could even push it for another 100+ potentially.
    WILLINH likes this.
  9. Sep 16, 2021 at 8:38 AM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Check that other thread for lots of details.
    TLDR
    Trust the light, not the Miles to Empty.
    The light always comes on with about 5-7 gallons remaining.
    The DTE calc is not dynamic. It will take a measure when you fill fuel, but never adjust based on how you're driving. One time I had the DTE go all the way to 10 left before the light comes on.
