Fuel tank replacement
Discussion in '1st Gen Tundras (2000-2006)' started by CocaDonut, Apr 30, 2025 at 7:30 AM.
  1. Apr 30, 2025 at 7:30 AM
    CocaDonut
    CocaDonut [OP] New Member
    Andreas
    2000 base Tundra Access Cab 4wd grey
    Hey everyone,
    Apparently i have a gas leak and my mechanic assumes it's from the gas tank. There might be a need to replace it. I've looked online for a bit but really haven't found much. Where do you guys shop for gas tanks? What brand? Is there somekind of universal gas tank I could use to replace it?
    Thank for your input
  2. Apr 30, 2025 at 8:11 AM
    Hmm, I used the search feature and very quickly came up with the following, which suggests the Dorman tank, and you must ignore the gallon-size discrepancy (Dorman under-reports the size). But hey, I guess we now have yet another thread for gas tanks :rofl:
    https://www.tundras.com/threads/2003-fuel-tank-availability.148856/
    https://www.tundras.com/threads/fuel-tank-leak.110991/
    https://www.tundras.com/threads/gas-tank-leak.96877/
    https://www.tundras.com/threads/gas-tank-options.150292/
    I wouldn't be comfortable with anyone "thinking" it's the problem. You either 100% confirm it's the problem, or you don't change the part. Both for your own reputation, and to save the customer's wallet. The fact he "thinks" that's the issue and wants to do a job that will indefinitely cost no less than $500 is ... well, that would scare the living shit out of me, to be honest.
    rouxster70 and CocaDonut[OP] like this.
  3. Apr 30, 2025 at 8:13 AM
    Fedtime
    Fedtime New Member
    Spectra Premium, TO32A is a decent choice.
    CocaDonut[OP] likes this.
  4. Apr 30, 2025 at 8:47 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Find another fucking mechanic.
    rouxster70 likes this.
  5. Apr 30, 2025 at 9:01 AM
    That good old, classic adage applies: When you ASSUME, you make an ASS out of U and ME.
    Assumptions can be a valid gateway to a hypothesis, and that hypothesis may lead you to a confirmed conclusion. But an assumption should never be the basis on which you put your wallet, without jumping into a hypothesis and landing at a confirmed conclusion. :thumbsup:
  6. Apr 30, 2025 at 9:06 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Exactly. This guy's on here asking for fuel tank recommendations when he really doesn't even truly know if that's the problem. I didn't mean to sound so harsh, but dammit, I feel like there are some mechanics who just like to pad their bill with big ticket items. Pisses me off.
    shifty`[QUOTED] and mustang67408 like this.
  7. Apr 30, 2025 at 9:18 AM
    Trust your mechanic to mend your car
    You bring it into his garage
    He tightens and loosens a few spare parts
    One thing's fixed, another falls apart
    Trust your mechanic to make you well
    You see an awful lot of him now
    The quicker he makes your life fall apart
    The more money you put in his pockets
    Trust your mechanic to plug your holes
    Trust him to make more somewhere else
    Trust your mechanic, he'll always come through
    And rip you off...
    https://www.youtube.com/watch?v=lVULKYbAeEo#t=0m56s
    ATBAV8[QUOTED] likes this.
  8. Apr 30, 2025 at 9:26 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Wow. I haven't heard that in like 35 years. Thanks for the memories.
  9. Apr 30, 2025 at 10:06 AM
    CocaDonut
    Andreas
    Just to clarify, he hasn't told me to buy one yet, just exploring my options in case it is the tank that is problematic.
    shifty` likes this.
  10. Apr 30, 2025 at 10:19 AM
    Basic smoke test with the gas cap attachment on a smoke machine will suss out a gas tank leak in under 3-4 minutes. It'll take longer to setup the smoke machine than it will to see if the tank is leaking. Smoke test would be the #1 diagnostic tool appropriate for the job.
    Note* that rodents love nesting in two places in these trucks:
    - Under the V8 intake manifold
    - On top of the gas tank
    When they do either, they typically chew fittings and wiring.
    Only saying this because, if the smoke leaks out from above the tank, it may not be the tank, it may be the tank fittings or fuel lines running out the top.
    CocaDonut[QUOTED][OP] likes this.
  11. Apr 30, 2025 at 10:55 AM
    CocaDonut
    Andreas
    Ahh that would make sense, i live in Montreal and the place is packed with squirrels.
    I appreciate the advice, will ask him to do a smoke test! Thanks alot
  12. Apr 30, 2025 at 11:09 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    You shouldn't have to ask. Very common test.
