Fuel Tank Pressure Sensor
Discussion in '1st Gen Tundras (2000-2006)' started by RNB112, Aug 26, 2025 at 8:40 AM.
  1. Aug 26, 2025 at 8:40 AM
    RNB112
    RNB112 [OP] New Member
    2005 Tundra
    I have a 2005 Tundra Crew Cab with 4.7 V8. I have a P0452 code. I've replaced the fuel cap. I have also smoke tested the fuel tank for leaks in the evaporator system. I have cleared the code and immediately upon startup, the code reappears. I am now looking into the fuel tank pressure sensor as the issue. Where is the sensor located? I have checked the top of the tank and there are two hose connections and one electrical connector which powers the fuel pump and provides the signal wire for the fuel level sensor.
    Any help would be appreciated.
  2. Aug 26, 2025 at 10:04 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The pressure sensor is part of the pump module in the fuel tank. It’s on page EC4 of the FSM which is available for download on this forum. May want to look at the Evap System troubleshooting section
    shifty` and The Black Mamba like this.
  3. Aug 26, 2025 at 12:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I second this
    Properly diag your issue instead of just throwing parts at it. Start with Section DI-311 in the FSM
