Fuel range dropping
Discussion in '2.5 Gen Tundras (2014-2021)' started by jeffiance, Mar 4, 2022.
  1. Mar 4, 2022 at 10:11 AM
    jeffiance
    jeffiance [OP] New Member
    Jeff
    2020 SR5 CrewMax
    I've been driving a 2020 sr5 offroad since August 2020 and after a fill the range has always displayed between 875-910 kilometres. I have a routine of filling at shell stations and always putting 91 in tundra and that hasn't changed since purchasing the truck. But about six weeks ago after a fill I noticed the range read 760km, a big drop from what I'm used to seeing and felt like my truck was drinking that tank fast. On the next fill my range read slightly less, 750km and then the next fill read 745km afterwards. Seems to always be dropping a few km after every fill but I don't notice any changes in performance or responsiveness in the pedal. Has anyone gone through a similar experience with their truck?
  2. Mar 4, 2022 at 10:13 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I've read it changes as your truck learns the real mpg average over time. Reset your truck and it will go back up.
  3. Mar 4, 2022 at 10:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you been manually calculating your fuel mileage? Do that to determine if your actual usage has changed.
    DTE is an estimate not exact science so don't read into it too much.
  4. Mar 4, 2022 at 11:30 AM
    jeffiance
    Jeff
    2020 SR5 CrewMax
    No just going off the display
  5. Mar 4, 2022 at 11:31 AM
    jeffiance
    Jeff
    2020 SR5 CrewMax
    I will try to unplug the battery and reset it
  6. Mar 4, 2022 at 11:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Winter fuels man...they've gotten worse...
  7. Mar 4, 2022 at 12:04 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Frankly I would just ignore it and go by your fuel gauge as far as when you need gas. If you monitor that "range" as an indicator something might be wrong, as stated above better to hand calculate your MPG.
    jeffiance[OP] and 1UP like this.
