Fuel Pump Running HOURS after car was turned off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DividedSky, Apr 2, 2019.
  1. Apr 2, 2019 at 3:41 PM
    DividedSky
    DividedSky [OP] New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I was out camping over the weekend... We pulled up to a spot around 5pm and I turned off the truck and removed the keys from the ignition. Sometime around 10pm, I noticed a humming sound and isolated it to the gas-tank area. I gave it about 5-10min and it didn't shut off, so fearing a dead battery in the morning, I removed the battery leads. When I reconnected them, the pump stayed off.
    Is this normal for the fuel pump to run like that HOURS after the vehicle was turned off and keys removed? I don't think that the pump ran the whole time... I think it came on a while after the keys were removed. Why?
  2. Apr 2, 2019 at 3:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I don't believe anyone has reported that on the forum. Hopefully someone will chime in with an answer.
  3. Apr 2, 2019 at 3:45 PM
    DividedSky
    Jeff
    Oh... and it could be something other than the fuel pump. Just isolated the sound to around the gas tank, so I assumed it was a fuel pump. could be something else in the same general location.
  4. Apr 2, 2019 at 4:27 PM
    IOWA18Trd
    IOWA18Trd New Member
    2018 Black Tundra TRD
    TRD Exhaust
    I believe this is totally normal. Both my wife’s Lexus and my Tundra do this about 5 hours after being shut off. Don’t hold me to it but I think it something to do with emissions.
  5. Apr 2, 2019 at 4:28 PM
    Never heard of it being on that long
  6. Apr 2, 2019 at 4:35 PM
    Booradly
    Booradly New Member
    Brad
    Regina, Saskatchewan
    2018 Tundra Platinun
    I have heard my truck do that a few times when I go out to the garage long often I parked it. No clue what it is.
    AggiePhil likes this.
  7. Apr 2, 2019 at 4:45 PM
    15whtrd
    15whtrd Mr. Blonde
  8. Apr 2, 2019 at 4:56 PM
    Im aware of the evap test, but it’s usually a few mins long and it’s done.
    t4r2tundra, 15whtrd and TXMiamiFan like this.
  9. Apr 2, 2019 at 5:35 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    My wife's 2019 4runner does it sometimes. I freaked out the first time i heard it. Same thing happened to me, about 3 hours after it had been parked in the garage, i went to take the trash out one nite and heard the humming. Sounded like a fuel pump running. I was like wtf?? Supposedly its a normal thing. New cars are weird.
    AggiePhil and 15whtrd like this.
  10. Apr 2, 2019 at 6:58 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    When we first got my wife's Sienna, I noticed it and thought something was wrong. Called the dealer and they said it's totally normal. I haven't noticed it on my Tundra yet because I've only had it a month and I park outside lol.
  11. Apr 2, 2019 at 7:04 PM
    TTund16 likes this.
  12. Apr 3, 2019 at 8:04 AM
    DividedSky
    Jeff
    Yeah, Coulda been the pressure test. It lasted at least 10 minutes. Long enough for me to hear it, find it, clear out my back seat to get to my tools (I was camping), pop the hood, loosen the bolt on the positive side, see it still won't budge and then do the negative side. That whole process took at least 10 minutes...
    Maybe it was because I had a very low fuel tank? Took a long time to build up the pressure for the test?
  13. Apr 3, 2019 at 8:17 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    My wife’s highlander does the same thing.
  14. Apr 3, 2019 at 8:19 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Mine does this whenever I am camping. 5-10 minutes. Annoying as hell since I sleep under the topper when car camping. Pretty sure it contributes to killing my battery in the winter when I'm not driving much. Not anymore with a Group 31 under the hood!
  15. Apr 3, 2019 at 8:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Normal. Freaked me out the first time while I was smoking late at night in the garage. I started up my truck and turned it off.
  16. Apr 3, 2019 at 8:41 AM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    Yeah, this happened on my 06 Tacoma all the time, still happens on my Tundra. I don't know the time frame, but I park my car by 7pm, I've heard it at 5:45 am in the morning. And yeah, I do hear it coming from back by the bed, right near the gas tank inlet, but towards the bottom center of the truck.
  17. Apr 3, 2019 at 8:52 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe when you’re camping, pull the fuel pump fuse. That way you can still have your battery connected.
  18. Apr 3, 2019 at 9:38 AM
    timsp8
    NY
    My 2010 did this a few hours after turning it off sometimes. Ran for a few min. Havent noticed it on my 18 yet.
  19. Nov 24, 2019 at 9:27 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    Not to revise an old topic but just came out to my truck and heard a humming from top of fuel tank. Truck has been parked for about 5 hours..... so I’m guessing nothing to worry about?
  20. Nov 24, 2019 at 9:44 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    It's normal. All newer vehicles do it.
    Chris001[QUOTED] likes this.
  21. Nov 24, 2019 at 9:58 AM
    SG TRD
    SG TRD New Member
    my 16' does it also. to make it stop i unscrew the gas cap to depressurise the tank.
  22. Nov 24, 2019 at 10:04 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The evap year can be long or short depending on outside conditions. Perfectly normal. Don’t try and mess with the gs cap or anything, can set a light because it’ll think there’s a evap leak.
  23. Dec 16, 2020 at 6:15 PM
    Matthews Barn Quilts
    Matthews Barn Quilts New Member
    Kelly
    NC
    2018 Tundra Crew Max
    Same here, I have heard my truck do that a few times when I go out to the garage long often I parked it. I switch it on then back off and it stops. I can't see how this could be good for the fuel pump.
  24. Dec 16, 2020 at 6:31 PM
    empty_lord
    05 rollover special
    It isn’t the fuel pump, there is a vacuum pump on the charcoal canister that does a self test with the truck off after hours of sitting. It is to test the evap system that is all
  25. Dec 17, 2020 at 5:59 AM
    Kung
    KG, VA
    My '20 does it as well.
  26. Sep 15, 2021 at 3:59 AM
    smithsl1
    smithsl1 New Member
    2018 Tundra TRD
    Hello everyone. I’m new to the forum. Thanks for having me.
    I wanted to report that I walked outside this morning around 0615 and I heard the same humming noise coming from my 2018 Tundra. Maybe the hot and humid environment triggered the evap. Same location as reported by others, right above the fuel tank. I shot some video before I read that it was a normal process. You can clearly hear the humming.
    Thanks for all the great information.
  27. Nov 13, 2021 at 9:27 PM
    Smallmouth King
    Smallmouth King New Member
    2021 Tundra Limited 4x4 Crewmax
    Bakflip MX4, Husky Liners X-ACT
    I can confirm that this happens on 21 models too. Thanks.
  28. Nov 14, 2021 at 5:03 AM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Glad I stumbled across this thread. Wife called me while I was at work several weeks ago and said the truck was making this noise. Obviously had stopped by the time I got home. Now we know!
    NewImprovedRon likes this.
  29. Nov 15, 2021 at 12:01 PM
    Rocko9999
    Rocko9999 New Member
    Normal, my 2021 Rav4 does this too.
  30. Apr 11, 2022 at 6:33 PM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Good info! Just discovered my '16 doing this tonight when I had to walk to the garage for something. Never heard this on any other vehicle in my life. Crazy.
    hANNAbONE likes this.
