Fuel pump running excessively
Discussion in 'General Tundra Discussion' started by Tundra_what, Jun 2, 2024.
  1. Jun 2, 2024 at 7:48 AM
    Tundra_what
    Tundra_what [OP] New Member
    I have a 2013 tundra, 4.6L. The fuel pump is running excessively. When the truck is off, no key in, the pump will intermittently run by itself. Also when key is turned to the on position but not started the pump will continue to run. Usually the pump will come on to build pressure then kick out. This has over time killed my battery. Relay is fine, changed the pump, cleaned all the ground connections, has anyone else had this issue?
  2. Jun 2, 2024 at 8:39 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    On tundras, the fuel pump only runs when cranking and when the truck is actually running. The pump does not run in key “on” position for priming or anything like that. What you may be hearing is the evaporative emissions system that makes a sound that sounds like the fuel pump when the truck is off. It will usually initiate 5 hours after the truck has been turned off.
    Saltyhero13 likes this.
  3. Jun 7, 2024 at 12:20 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    If it's not the evap system then have you ruled out the fuel control module. Usually they just die. But worth looking into.
  4. Jun 7, 2024 at 6:07 AM
    Tundra_what
    Ok, thanks Silver17 and MDL, I'll check out the evap system.
