Fuel Pump Out on 2018 FFV
Discussion in '2.5 Gen Tundras (2014-2021)' started by jptshadow, Jan 3, 2020.
  1. Jan 3, 2020 at 1:21 PM
    jptshadow
    jptshadow [OP] New Member
    Hey u'all. The PreCollisionWarning light on along with Trailer Brake Error (which I have never towed anything). Truck is still running fine with the lights on. It was a bit harder to crank up at the beginning of the day tho. MPG has no changes with E85 since day one.
    So brought her in and they later determined it was the fuel pump going haywire which triggered the whole false signals (meaning the PCW and Trailer Brake are actually ok). Now they said they are gonna pull the whole gas tank apart and fuel line the whole deal apart to see what causes the fuel pump to run out. If it's fuel pump itself, then Toyota will pay for it, if it's bad gas causing that, then I will be responsible which is 2600 plus tax.
    Anyone experiences this??
    Fourknights likes this.
  2. Jan 3, 2020 at 1:24 PM
    timsp8
    NY
    Never heard of it, but even new parts can go bad. But that is complete BS that you have to pay if it was bad gas. 1 tank wouldn’t make a pump fail. How do they know where you have been filling up the whole time you had the truck? Unless they find diesel in the tank, I’d argue that all day.
  3. Jan 4, 2020 at 5:43 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Did I read this right? The dealer threatened a $2600 bill on a truck still under the bumper to bumper warranty?
    Y0TA PR0 likes this.
  4. Jan 4, 2020 at 9:30 AM
    jptshadow
    They said if it's "contaminated gas", it's on me. Not sure how to fight that logic?
  5. Jan 4, 2020 at 9:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    They're probably going to look for free trash in the tank that is obviously obstructing the filter. Beyond that, it will be very hard to claim any other kind of fuel contamination. Retail gasoline pumps have a spin-on filter to remove any storage tank trash and water. Fuel contamination happens, but it is rare. Any expense you incur can be claimed back against the fuel retailer. You should be fine unless you buy your gasoline in rusty five-gallon cans that you wash out with the garden hose. ;)
    You must have a perfect a-hole for a dealer. They are stating the obvious, i.e. that they are not responsible for your mistakes and/or abuse, but you would think they would wait until they discover some obvious evidence of malfeasance. :notsure:
    panicman likes this.
  6. Jan 4, 2020 at 11:43 AM
    JohnLakeman
    @Ronin73 found a TSB that relates to FFV fuel pump. You might find and review the TSB and see if it applies to your truck:
    Complete thread here: https://www.tundras.com/threads/tsb-and-warranty-question.59647/
    Voyagermike likes this.
  7. Jan 5, 2020 at 3:42 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
  8. Jan 5, 2020 at 4:27 AM
    JohnLakeman
    :thumbsup: Thanks @Ronin73
    @jptshadow You can buy the TSB with a short term subscription to Toyota Information Service, but I would insist the dealer's service dept look it up for themselves.
    Ronin73 likes this.
  9. Jan 5, 2020 at 4:50 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Just watched and saw about the fuel pump replacement. Was hoping to get away with just a reflash since I’ll be out of pocket.
  10. Jan 5, 2020 at 4:56 AM
    JohnLakeman
    @jptshadow NOTE that the video says that the required seal has been OUT OF STOCK because so many FFV owners have had this TSB done. Don't let them take your truck apart until they have received the seal!
    jtwags, Brownsfanhere and Ronin73 like this.
  11. Jan 13, 2020 at 5:59 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I have done the red flash but the issue came back. I am well out of warranty. I was told the fuel pump is back ordered till Jan 30th. Cost is going to run around $1300. They reflashed it again, so hopefully I will be good till pump comes in. It was the second Tundra in the shop today for that issue at Gulf Coast Toyota. Given that this truck has 120k miles I am not worked up about it. It has not left me stranded, and Toyota took care of me with cam tower leak. I did have to prepay for them to order a back ordered pump. Had to laugh about that. I think pump was around $600.
  12. Jan 13, 2020 at 6:09 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Have a ffv. Is this because one is using E85 or not related. Never use e85. Just 87 octane. No issues so far.
  13. Jan 13, 2020 at 6:37 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Welcome to the wonderful world of FFV ownership. Had my fuel pump replaced last year for some hard/rich condition starting issue. Toyota dealer charged $750(new pump+ labor). $2600 sounds like rape. Fast forward to the last couple of weeks of cold temp starts.... Rich starting condition on 2 separate occasions. Once on a full tank of Chevron super and another on ethanol free 88. Both when temps were in the 20°'s. No issues starting above the 30° mark. Best of luck. That quote is garbage.
    Edit: BTW pump was about $530 and the dealership comped me an hour of labor due to them screwing up some other part of my service ticket.
  14. Jan 13, 2020 at 6:51 PM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
  15. Jan 13, 2020 at 6:55 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Classic Toyota balking at fixing their trucks
  16. Jan 13, 2020 at 7:26 PM
    ZPMAN
    Minnesota
    I did see the video from Tundra dude 3 days ago and yesterday getting the Highlander serviced I asked my service manager about the TSB and we couldn't find anything. Since installing the supercharger I only run 91 non ox and have on occasion had my ethanol % checked and 0ed out. Still kicking my self for not going out of state for a non FFV Tundy.
  17. Jan 13, 2020 at 7:49 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  18. Apr 19, 2021 at 2:28 PM
    Crow52LA
    Crow52LA 4x4 sport horns in the air
    North East Los Angeles
    19 MGM SPORT CREWMAX 4x4
    Gangster
    I'm having the same issue. Did they ever figure out what exactly it was?
  19. Apr 21, 2021 at 10:56 AM
    jptshadow
    Check if they have a recall on your fuel pump. Thaz what happened to mine last year.
  20. Apr 21, 2021 at 11:53 AM
    Crow52LA
    Gangster
    Got bro thanks
  21. Apr 21, 2021 at 12:40 PM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    As far as i understand, their fix is a replacement fuel pump (Delphi FE0707 / OEM 2320-0S011) of the exact same model but a "new" batch. Sad thing is they have been using that part since ffv was introduced, but the recall only applies to certain years. Because that leaves a bunch of us 2015 owners left out to dry, theres a class action suit ongoing. We'll see what comes of it. But since there isn't an improved fuel pump available, I got the reflash and purchased an aftermarket pump from URD to wire in the old ones place (with higher flow capabilities for when I cash in some bitcoin for a whipple supercharger). Will post a new thread when i find a day to actually do it, sitting in the garage until then.
  22. Apr 21, 2021 at 12:48 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I had the fuel tank recall done on my 2019 4.6L It’s not the pump but rather a sensor attached to the pump.
    jptshadow[OP] likes this.
