Fuel pump access cover for truck bed.
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Jan 27, 2021.
  1. Jan 27, 2021 at 7:49 PM
    evilrb
    evilrb [OP] New Member
    Jeremy
  2. Jan 27, 2021 at 10:05 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    That's pretty cool but, just how often are you working on your gas pump?
    Darkness likes this.
  3. Jan 27, 2021 at 10:20 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m not really understanding what the need for this is. Your fuel pump might easily last 10 to 15 years. Cutting the hole in the bed compromises the paint and could allow dirt, dust, water, etc to drop onto the tank and various components. Please explain what I’m missing, what is the up side?
    Luckydog likes this.
  4. Jan 27, 2021 at 11:50 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the tanks so easy to drop.. i wouldnt worry about it. unless youre fixing a rotted out bed. theres no real need for this.
  5. Jan 28, 2021 at 1:34 AM
    evilrb
    Jeremy
    Well since I'm upgrading to an Aeromotive 320 pump for the supercharger I figured that it was an easy thing to do since I'm already in there the first time.
    Tanks are easy to drop but I'm usually a 1 man show and I absolutely hated the process on my 4runner..
    Kinda turned me off to the job.
    Had to replace the pump 4 times in a month with just a stock Denso unit from Autozone... a long messed-up story that drove me crazy.
    I just figured I'd ask if anyone has done it before like the 4runner guys do.
    If not it's only like $30-$50 for better piece of mind.
    Plus I'm spraying my bed with rhino lining so it's an easy job to get a nice finish result.
    gosolo likes this.
  6. Jan 28, 2021 at 3:47 AM
    Professional Hand Model
    Hand Protectors
    Do it and report back!
  7. Jan 28, 2021 at 5:18 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Never knew you could buy something like that. I think it's a good idea if it keeps you from dropping the tank or pulling the bed. Especially if you're going aftermarket and might need to service it again in the future.
  8. Jan 28, 2021 at 5:34 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    GM owners were well known for cutting an access door through the floorboards of certain vehicles because dropping the tank was a royal PITA. Measure twice, cut once.
    The OEM pump had enough juice to supply the OEM blower, so why ‘upgrade’?
    FirstGenVol and Gunship Guy like this.
  9. Jan 28, 2021 at 5:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is it possible that dropping the tank on the 4Runner is worse because it has less ground clearance than our trucks? I feel like I could use a floor jack, with a piece of lumber to stabilize, and easily lower the tank to the ground. It would help if it's close to empty.
  10. Jan 28, 2021 at 8:31 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This makes sense, I understand
  11. Jan 28, 2021 at 2:52 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I already have “access” holes to my gas tank from the bed rust underneath my bedliner. Wasn’t my choice but good to know they have a purpose. :D
  12. Jan 28, 2021 at 2:54 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Any particular reason for the aeromotive instead of a denso mk4 tt pump? The denso is actually a larger diameter and stouter feeling unit than the aeromotive/walbro sized pumps.
  13. Jan 28, 2021 at 5:41 PM
    evilrb
    Jeremy
    I have a brand new one with FPR leftover from another build, that's all
