Fuel problem
Discussion in '1st Gen Tundras (2000-2006)' started by Christrain, Jul 1, 2021.
  1. Jul 1, 2021 at 8:48 AM
    Christrain
    Christrain [OP] New Member
    Yuri
    2003 Toyota tundra
    Hi all i have a problem i put a new fuel pump worked for two days and it stop working i thought it was defective so i went out bought new one again and day later same thing so i disconnected fuel line and turned the key no fuel pump not working again so can someone please tell me whats going on and i bought new fuel pump relay that was not the problem still no fuel pressure. Help please
  2. Jul 1, 2021 at 9:10 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Have you replaced the fuel filter? It could be clogged.
  3. Jul 1, 2021 at 9:18 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s either clog somewhere, or electrical, fuels relay etc
  4. Jul 1, 2021 at 9:19 AM
    Christrain
    Yuri
    2003 Toyota tundra
    I changed everything filter, relay but when i spray starter fluid in brake booster vaccum line she stays running by starter fluid but i stop spraying she dies out no fuel
  5. Jul 1, 2021 at 9:20 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Connection to fuel pump, maybe a lose ground somewhere
  6. Jul 1, 2021 at 9:22 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The easiest is take the fuel pump and connect to a 12v see if it spins. If it spins that’s mean a lose connection somewhere
  7. Jul 1, 2021 at 10:16 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    My $$$ says it's not the pump. You have a wiring/relay/switch problem somewhere in the fuel pump circuit then. Test it and verify before throwing parts and $$$ at the issue. You need a voltmeter or 12v test light. Follow the wiring from the fuel pump back to the first connection you find and test the electrical connection there. If there is power to that point then you need to keep tracing it back until you find where exactly it is not getting power. Logic is your friend here.
    Roborob70 and Darkness like this.
  8. Jul 1, 2021 at 12:56 PM
    Christrain
    Yuri
    2003 Toyota tundra
    Ill check on that someone told me it could be (fuel pump resistor) too. but ill use test light from the tank to wire harness thanks ill keep you guys posted.
    Desert Dog likes this.
  9. Jul 12, 2021 at 6:06 AM
    Desert Dog
    OP, you ever solve this problem?
    Tundra2 likes this.
  10. Jul 12, 2021 at 8:50 AM
    Christrain
    Yuri
    2003 Toyota tundra
    Yes i solved the problem it was everytime i lift the tank into place the plug would come off. I tried fow time starting it started and went through rough street and didnt come off. Thanks and now i have different problem ots running rough now and shaking it never did that before the fuel pump. I put new sparkplugs right about now it have every sensor new even coils but check engine light not on. Has no power l
    Sound like bogging out like dam honda when they put air cleaner tube.
  11. Jul 12, 2021 at 8:58 AM
    Desert Dog
    Good to know you solved the issue.
    Have you checked to verify that you fully seated the plugs and didn't leave one or more loose and/or the coils are connected to the correct plugs? Sounds like an electrical issue again to me.
  12. Jul 12, 2021 at 11:56 AM
    Christrain
    Yuri
    2003 Toyota tundra
    There all tight. Never had this problem until i put the fuel pump now this happening ill see if can make short video so you can see and hear it soon.
  13. Jul 12, 2021 at 12:07 PM
    Desert Dog
    A video may help. I'd recommend checking your fuel pressure at the fuel rail and make sure the pressure is in spec before tearing back into the tank/pump or anything else. Just out of curiosity did you verify that the fuel pump installed is the correct one for your application?
    Sirfive likes this.
  14. Jul 12, 2021 at 12:11 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Verify pressure, then verify/clean injectors. I dunno about toyotas, but jeeps you build a rig with a water bottle of injector cleaner, a hose, and a 9v battery. Squeeze the bottle to make the flow. Itll also click when you connect the jumer wires to the battery. I dont know if its bad to leave them on, i always flutter the signal.
  15. Jul 12, 2021 at 12:21 PM
    Desert Dog
    Yes, he could test the injectors but I don't believe that's the issue. Note that he states in his opening comment that the truck was fine for 2 days before needing to replace the pump a 2nd time. No mention of running issues prior to the 1st pump replacement.
  16. Jul 12, 2021 at 12:25 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Still worth a test. Maybe the wiggling and jiggling sent some junk down the line?
  17. Jul 12, 2021 at 12:35 PM
    Desert Dog
    Possible. There are still some unknowns in this scenario. Fuel rail pressure test will reveal more.
    OP, which engine is in this truck? 6 cyl or 8 cyl?
  18. Jul 12, 2021 at 1:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    What fuel pump did you use?
    Hose not clamped properly inside tank could cause low fuel pressure and rough running issue. Or old hose re-used and developed a leak.
  19. Jul 13, 2021 at 5:08 AM
    Christrain
    Yuri
    2003 Toyota tundra
    I put new fuel pump ots starts runs everytime i turn the key now its running in few seconds after starting that when she get rough idle and no power the fuel pump is recommend for my truck 2003 4.7
  20. Jul 13, 2021 at 5:13 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Sounds like my prom night.
  21. Jul 13, 2021 at 6:42 AM
    Desert Dog
    Ok, but did you check your fuel pressure at the fuel rail? If not that is the next logical thing to do. Verify the pressure is in spec then let us know what the pressure reading is and we'll go from there.
