Fuel Pressure test
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scott1794, Nov 18, 2024.
  1. Nov 18, 2024 at 1:11 PM
    Scott1794
    Scott1794 [OP] New Member
    I've searched without a definitive answer so I'm asking here. I want to test my fuel pressure but I cannot find an answer on how to release fuel pressure before I hook up equipment. Will removing the fuse and relays and then cranking do this? If not, can anyone explain how to remove the plugs on the fuel pump controller ECU. Tight spot and I can't find the tabs to depress to release. Thanks in advance.
