Fuel mileage and auto start
Discussion in '2.5 Gen Tundras (2014-2021)' started by advwthn, Dec 26, 2024.
  1. Dec 26, 2024 at 8:13 AM
    advwthn
    advwthn [OP] New Member
    jerimiah
    2108 toyota tundra
    OTT tailor tuned, brakes, winch and bumpers
    Ill start off by saying I added a winch to my truck. Disassembled the grill to do the wiring right. I also added a new yellow top 27f group battery.
    I ran the truck normal, I went home and tried to use my auto start and it will not function now. I proceeded to drive around a bit, said what the hell ill get fuel. I filled up with 88 octane as usual. Left the station an noticed my fuel economy went from 430 meg's per tank to now over 600 mpg's.
    At a loss about this
  2. Dec 26, 2024 at 8:18 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    When you disconnected the battery you reset the "memory" associated with the fuel range per tank. After a tank or two I'm sure your numbers will revert to normal.
    The auto start not working likely has to do with the battery being disconnected as well. Is this an aftermarket automatic start system or the OEM remote start?
  3. Dec 26, 2024 at 8:20 AM
    advwthn
    jerimiah
    2108 toyota tundra
    i'll keep an eye on that through these next tanks. no this the factory auto start, it's sequence is the 3 clicks on the lock and it would beep twice then start
  4. Dec 27, 2024 at 7:45 AM
    advwthn
    jerimiah
    2108 toyota tundra
    Still no fixes yet.
  5. Dec 27, 2024 at 12:03 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Normal. Once you visit the gas station a couple more times, your range will resume the normal range you’re used to seeing.
  6. Dec 27, 2024 at 12:20 PM
    advwthn
    jerimiah
    2108 toyota tundra
    Still unable to get the factory auto start to work. Erased codes. Still not working
  7. Dec 29, 2024 at 10:11 PM
    Bullshawrk
    Bullshawrk New Member
    i thought on factory key its 3 clicks on the third you hold it?
  8. Dec 30, 2024 at 4:51 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    It is
  9. Dec 30, 2024 at 5:51 AM
    What codes?
