Fuel gauge always on
Discussion in '1st Gen Tundras (2000-2006)' started by 3bears, Aug 29, 2024.
  1. Aug 29, 2024 at 9:08 AM
    3bears
    3bears [OP] New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    only owned a while now, but yeterday I noticed that when I shut the rig off all gauges go to zero, except fuel gauge stays right where it was when running. Is this normal. also I have suspected a parasitic draw but no time to chase, maybe this is it
  2. Aug 29, 2024 at 9:13 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    It's normal. I've had a few different toyotas from this era and they all do it.
    Just stays resting at last position, if you've noticed when you fill up with gas it doesn't go up until you turn the key on so it shouldn't be using any power.
  3. Aug 29, 2024 at 9:14 AM
    shifty` In South Dakota Trouble ain't hard to find
    Most fuel senders in modern vehicles I've dealt with are all resistance-based. As in, there is not really any voltage required, the needle stays pegged base on how much resistance exists on the wire out & back.
  4. Aug 31, 2024 at 9:45 AM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    ok, thanks all, I noticed because when I drive my 2000 4runner the gauge goes to empty when I shut the key off
  5. Aug 31, 2024 at 9:59 AM
    If you're not familiar with how to test for parasitic draw ... Skip to 18m31s if it doesn't auto-start there.
  6. Sep 1, 2024 at 8:49 AM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
