Fuel Evaporation Leakage Check (Fuel Pump On)
Discussion in '2.5 Gen Tundras (2014-2021)' started by KCTundra, Jan 16, 2017.
  1. Jan 16, 2017 at 6:58 PM
    KCTundra
    KCTundra [OP] -Caeleb
    Caeleb
    Kansas City
    2016 Crewmax Platinum
    3/2 Ready Lift, 35" Nitto Trail Grapplers, 20x10 Fuel Assault Wheels (-18 offset / 4.75" backspace), BAM Budget Exhaust
    So tonight I went out to get something out of my garage and heard a sound that was coming from under the truck. Discovered that it was the fuel pump. I thought "WTF is that? Now I gotta dead battery and gotta take the thing into the dealer tomorrow". Found out it was normal but thought I'd share a video of what it sounds like.
    https://youtu.be/GP0jOi-ziSM
  2. Jan 16, 2017 at 7:09 PM
    Yes, 100% normal. It's self testing. My wife's highlander does this as well
  3. Jan 16, 2017 at 7:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I smoke in my garage and that sound freaked me out too. But what caused your battery to die?
  4. Jan 16, 2017 at 7:47 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    My wife's IS 350 F does that too...normal for that car.
  5. Jan 16, 2017 at 9:26 PM
    KCTundra
    Caeleb
    Kansas City
    I was thinking that before I found out it's normal!
  6. Jan 16, 2017 at 9:51 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    How is it normal if it drains your battery? Is there a timer to make it run every so often? Does the switch get stuck?
  7. Jan 17, 2017 at 1:55 PM
    STL22JS
    STL22JS New Member
    2016 Tundra CM
    My 2016 makes the same noise - at first is a little shocking when you hear it. Now I'm just used to it.
