Fu-Man-Chu paint while on truck????
Discussion in '3rd Gen Tundras (2022+)' started by grnwdjsn, Oct 31, 2023.
  1. Oct 31, 2023 at 10:49 AM
    grnwdjsn
    grnwdjsn [OP] New Member
    2023 Tundra Limited TRD Offroad
    Has anyone painted the fu-man-chu trim while still on the front of the truck? I was curious to see if it was a nightmare or not. Weighing the prospect of ripping the entire front of the truck off or just living with silver. I recently replaced the back bumper silver with flat black (after cracking one of the silver panels). I love how it turned out so now I am thinking about the front.
  2. Oct 31, 2023 at 11:32 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
  3. Oct 31, 2023 at 11:50 AM
    fat_marshmallow
    fat_marshmallow New Member
    i did, tapped and plastic wrapped all around. it was pretty easy to do. I was going to take off everything to do it but decided not too for time sake. Then i sand, prime, paint, clear. cant tell it was painted. been a year and through rain, dirt, hail, winter and still looks good damages. only cost me under $150 to do everything. Best money spent on the exterior of the truck so far.
    CringyDad, pwpblue, Siblue and 9 others like this.
  4. Nov 1, 2023 at 4:01 AM
    grnwdjsn
    OK! That looks pretty awesome. Thanks for the photos.
  5. Nov 2, 2023 at 4:07 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    If it looks as good in person as it does in the pics, that turned out very well. Kudos.
  6. Nov 2, 2023 at 6:51 AM
    fat_marshmallow
    thanks! yea it looks OEM. no one can tell it was painted unless I tell them.
  7. Nov 2, 2023 at 3:38 PM
    Rafael707B
    Rafael707B New Member
    Rafael
    2023 Toyota Tundra Platinum
    Stock
    Where did you get the color match? i have the celestial silver and want to do the same thing.
  8. Nov 2, 2023 at 4:22 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    If you're paint skills are questionable and you are worried about screwing something up you could always try plasti dip. It wouldn't be glossy, but would be quick and easy to apply and you can peel it off if you don't like it.
  9. Nov 3, 2023 at 7:08 AM
    EC1
    EC1 Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    And we're award winning now!
  10. Nov 3, 2023 at 7:56 AM
    fat_marshmallow
    i got the paint from touchupdirect.com. paint match was spot on.
    thanks!! she only destroys mall parking and home depot parking lots for now haha
    ScootARoot likes this.
  11. Nov 3, 2023 at 11:05 AM
    Rafael707B
    Rafael
    Stock
    Did you do the aerosol can or actual spray booth paint?
  12. Nov 3, 2023 at 11:06 AM
    Rafael707B
    Rafael
    Stock
  13. Nov 3, 2023 at 11:50 AM
    fat_marshmallow
    I got the aerosol only. I used self etching primer and 2k clear coat from Eastwood. 1 can was enough for me to do 3 color coats with still a little left in the can. 1 can of 2k clear was enough for me to do 3 coats as well.
    Rafael707B[QUOTED] likes this.
  14. Feb 4, 2024 at 5:20 PM
    Big Baker
    Big Baker New Member
    2022 Tundra Limited 2WD in Blueprint
    I was just looking at touchupdirect.com and thinking about buying their Color-Matching aerosol spray. I want to paint my moustache and fender flares to match my “Blueprint” truck color.
    Did you sand - Prime - and paint the moustache yourself?
    How's your paint job holding up?
    Do you have any "Lessons Learned" advice for me?
    Mattedfred likes this.
  15. Feb 5, 2024 at 8:27 AM
    fat_marshmallow
    yep i painted it myself in the garage.
    i sanded the mustache with 320 grit to where the mustache was dull. then self etching primer. then wet sand the primer with 400 grit. painted 3 coats color. 3 coats 2k primer.
    it's been a little over a year, still holds up great! no peeling/flaking, anything. I even took it off to install the heritage grill also. again it's been through rain, touchless carwashes weekly, dirt, snow, hail etc. still holds up fine.
    i've painted a good amount of parts from my F*ckboy sh*tbox car days so I had some "experience" with garage and rattle can paint jobs lol...just get decent quality primer and clear. take your time prepping. make sure your workspace is not dirty or dusty. prep is key. again take your time with the prep work.
    CringyDad and Troyboy84 like this.
