FS - Tundra Parts - ***All Sold***
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by NuTundra18, Aug 17, 2020.
Thread Status:
Not open for further replies.
  1. Aug 17, 2020 at 5:42 AM
    NuTundra18
    NuTundra18 [OP] New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    1. ***SOLD*** TRD Pro Shift Knob and TRD Leather Boot already installed. $85 + shipping. The item is new in box and never installed. Going in different direction. This shift knob is for those that are converting to a TRD PRO shift knob and boot. Direct replacement. Please note, the shift knob was not altered or damaged in anyway to install the boot. Some have filed down the white cap end to get the boot on, but what I did was remove the metal ring on the boot to get it slid over the knob and zip tied.
    2. ***SOLD*** Factory Dual USB port for front or rear replacement of factory 12v socket. This is a direct plug and play port. The pigtail ends have been modified for direct plug into factory harness so no cutting of wires. See detailed pics. $30 + shipping.
    3. ***SOLD*** Factory "New In Box" bed rail tie downs (4) for Toyota Tundra or Toyota Tacoma bead rail system. $50 + shipping.
    All items are located in Florida.
  2. Aug 17, 2020 at 6:41 AM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Pm sent on the 12v
  3. Aug 18, 2020 at 5:07 PM
    afk237
    afk237 New Member
    Aaron
    2021 TRD PRO Tundra 2022 TRD PRO Sequoia
    New to the forum and browsing the for sale section. What all is required to modify the gear shift “cluster area” for that shifter and boot. Is the mod just covering that square area the shift gate is in, or is there another piece that allows the gear indicators on the side to still be seen? It looks like it would be a significantly nicer mod than the stock shifter.
  4. Aug 18, 2020 at 5:12 PM
    NuTundra18
    Jimmy
    That’s correct, just a way of adding a nicer Knob and boot to cover the square plastic that gets real shiny in the sun. If you search the boards you will see where folks added thee to the Tundra and they look great. The knob is much nicer than the stock tundra knobs too.
  5. Aug 18, 2020 at 6:22 PM
    Welcome from NY.
    Simple 10 minute install. Unscrew your shifter, pull trim up, place boot thru shifter rod, tuck in boot, push trim back in place then thread shifter knob back on.
    biebs96 likes this.
  6. Aug 18, 2020 at 6:23 PM
    biebs96
    PA
    Pm sent
Thread Status:
