FS: Element Hard Parts Tundra 07+ Chromoly Uniball UCA
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by Shanet421, Sep 17, 2023.
Thread Status:
Not open for further replies.
  1. Sep 17, 2023 at 7:02 AM
    Shanet421
    Shanet421 [OP] (Semi) New Member
    San Diego,CA
    These were used for only a couple thousand miles. Uniballs are very tight and bushings are still new. Ready to run!
    Shipping at buyer expense.
    Local San Diego pickup
    $450 OBO
    Roomy and with a big V8 engine pushing out plenty of power, the Toyota Tundra is a great truck. Our Element Hard Parts Tube Upper Control Arms can help make your Tundra even more capable, functional, and versatile. Built to be affordable without cutting corners, our Tube Arms use the same massive 1-inch FK uniballs found on our Billet Upper Control Arms with heat-treated stainless steel races. Complementing the big balls are our custom-machined heat-treated 17-4 stainless steel pins for a big increase in strength. The rest of the arms are just as stout constructed from CNC-bent 4130 chromoly with 1.50-inch diameter, .120-inch thick tubing. Further separating our Element Hard Parts Tube Upper Control Arms from the rest of the pack are our innovative squeak-free bushings. Their unique, bind-free design requires absolutely no grease or maintenance. And, they eliminate the annoying squeaking that can occur with other bushings often leading to insanity. The bushings are built to last and are backed by a lifetime warranty. Our Element Hard Parts Tube Upper Control Arms add strength, provide coil clearance, make alignment simple, and maximize wheel travel.
  2. Sep 20, 2023 at 4:16 AM
    Shanet421
    San Diego,CA
  3. Sep 24, 2023 at 9:10 AM
    Shanet421
    San Diego,CA
  4. Oct 1, 2023 at 8:17 AM
    Shanet421
    San Diego,CA
  5. Feb 14, 2024 at 12:35 PM
    Shanet421
    San Diego,CA
    Sold…thanks guys
Thread Status:
