Frozen shackle bolt!!!! HELP
Discussion in 'Suspension' started by MiYota, Mar 12, 2019.
  1. Mar 12, 2019 at 11:35 AM
    MiYota
    MiYota [OP] New Member
    evan
    2014 super white tundra
    I am in need of any and all ideas to help with a frozen shackle bolt. I am taking off the factory shackles and the bolt that goes thru the factory shackle and leaf spring appears to be frozen inside the sleeve. Who has got some ideas to free it up. I am almost at the point of cutting the shackle and trying to get it out that way but I really don't want to do that. Thanks all in advance.
  2. Mar 12, 2019 at 11:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Did you try the biggest breaker bar along with a cheater that you could find? If you’re like me and don’t have a large compressor and impact, you may need to find someone that does. Or borrow a big electric impact.
  3. Mar 12, 2019 at 11:50 AM
    MiYota
    evan
    I have the nuts off and the outside piece off but the inside piece with the studs pressed in appears to be stuck in the metal sleeve inside the leaf spring bushing.
  4. Mar 12, 2019 at 11:56 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I would buy the poly bushing from coachbuilder or toytech first. Then ball press or bang that sleeve out and install the poly.
    Black Wolf likes this.
  5. Mar 12, 2019 at 12:44 PM
    Yep...would have nice to have the poly's beforehand. Sounds like breaker bar time as mentioned or impact.
    15whtrd likes this.
  6. Mar 12, 2019 at 12:45 PM
    TheBeast The Beach
    heat it up ! :bananadead:
  7. Mar 12, 2019 at 12:46 PM
    TheBeast The Beach
  8. Mar 12, 2019 at 1:19 PM
    MiYota
    evan
    I am trying to find the bushing kit on toytecs site, any one have a link?
  9. Mar 12, 2019 at 1:23 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
  10. Mar 12, 2019 at 1:24 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @MiYota Are you getting the shackles too?
  11. Mar 12, 2019 at 1:28 PM
    Twinky
    07 double cab work horse
    Hit the leaf or shackle with a hammer. Dont hit the bolt.
    Also, do you have the back pf the truck off the ground? If so are both sides suported equally?
  12. Mar 12, 2019 at 1:34 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Try to alternate prying on the bottom and top bolts. Those bolts are connected to the schackle if you don’t know already. Plus make sure theres no weight on the leafs.
  13. Mar 12, 2019 at 1:35 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    This happened to me when I installed new shackles. Since I was replacing that lower bushing as well, I cut the bolt to remove the inner OEM shackle piece, then used a combination of hammer, chisel/screwdriver, drill, saw and cutoff wheel to finally remove what was left of the bushing.
  14. Mar 12, 2019 at 1:35 PM
    MiYota
    evan
    I have the Camburg shackles that i am going to be using. bought them off of here and got an awesome deal.
  15. Mar 12, 2019 at 1:37 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Heat that bitch up with a torch and smack the shit out of it with a hammer. Always works with stubborn/rusty bolts.
    Faht Nocker likes this.
  16. Mar 12, 2019 at 1:41 PM
    MiYota
    evan
    Just got off the phone with Dave at Coachbuilder. He said its common that the driver side get frozen together. He is going to over night the poly bushing so tomorrow morning I am going to plan on cutting the shackle in half to free it up and burning out the bushing. Thanks for all the replies. This is a serious PITA.
  17. Mar 12, 2019 at 1:48 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I assume that you had the vehicle jacked up (on stands) AND you had a jack under the rear diff to apply some load to it (bring it to neutral instead of full droop)?
    I just removed my rear shackle bolts and having good support on the diff was crucial.
    15whtrd likes this.
  18. Mar 12, 2019 at 1:51 PM
    MiYota
    evan
    Yes I did. Passenger side came out super easy and the bolt had no rust on them. Drivers side had rust all over the end of the bolt that is sticking out.
  19. Mar 12, 2019 at 2:12 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    @Coachbuilder1 Dave is a great guy and always very helpful
  20. Mar 12, 2019 at 2:14 PM
    MiYota
    evan
    Honestly a life saver. My truck is all apart and I need to make my alignment appointment on Thursday because I work Friday, Saturday, and Sunday. I would recommend them to anyone.
  21. Mar 12, 2019 at 3:22 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Spray the bolt down, then use an air chisel with a blunt bit it, the chisel will hammer it right out. I hit mine for 2 days, sprayed numerous time, even mushroomed the bolt from beating the shit out of it so much. On a whim, I tried my air chisel, 20 second later the damn thing was out. I cant explain it, it just worked.
  22. Mar 12, 2019 at 9:53 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Had this happened to me once, I had to cut it off.
