Front-wheel drive?
Discussion in '3rd Gen Tundras (2022+)' started by boomtime, Oct 10, 2023.
  1. Oct 10, 2023 at 4:54 AM
    boomtime
    boomtime [OP] New Member
    Anyone notice in the manual that the 4x4 switch is called the front-wheel drive switch? I was under the impression that in 2wd mode it is rear wheel drive.
  2. Oct 10, 2023 at 4:56 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    It is rear wheel drive. It's a typo. Look at the rest of the manual, it says four wheel drive.
    boomtime[OP] likes this.
  3. Oct 10, 2023 at 6:10 AM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    It is a typo. Toyota manuals are the worst for having oddities like that. I believe out of my last 5 Toyotas only one manual had the actual correct oil change reminder reset instructions.
  4. Oct 10, 2023 at 7:28 AM
    pursuit2550
    For that feature, does it at least have a quick disconnect?
  5. Oct 10, 2023 at 7:31 AM
    mass-hole
    mass-hole New Member
    I mean, that switch does control the front wheel drive, does it not? It turns the drive to the front wheels on and off.
  6. Oct 10, 2023 at 7:41 AM
    pursuit2550
    Well, "wheel drive" to me has always been known as what drives the vehicle forward. So to me if some said FWD, I take it as it only FWD. Same goes for 2WD or AWD. And while it does control the front wheel drive, it's also engaged with the rear wheels, making it a 4x4 wheel drive. Just thinking aloud for a friend.
  7. Oct 10, 2023 at 8:39 AM
    Breathing Borla
    Northern Illinois
    thats the way I read it, I think its right, it is the front wheel drive switch, rear wheel drive is all the time
    minium and boomtime[OP] like this.
  8. Oct 10, 2023 at 8:50 AM
    boomtime
    This interpretation makes sense to me.
  9. Oct 10, 2023 at 10:34 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Y’all must be fun at parties…… really?! I can see it now when the Ford guys drop in and see the Tundy fellers argue semantics regarding if their truck is front wheel drive. I’m sure the Tundra has option for front wheel drive.
    Eurodriver likes this.
  10. Oct 10, 2023 at 10:54 AM
    AZBoatHauler
    So.Arizona
    It is a switch to control drive to the front wheels so I’m struggling to see how it’s inaccurate.
    minium likes this.
  11. Oct 10, 2023 at 11:04 AM
    pursuit2550
    At least it's not a "how big a tire I can fit with a lift" or " how do I get more MPG out of a 6,000lb brick".
  12. Oct 10, 2023 at 11:20 AM
    coTony
    Tony
    Montrose, CO
    If I am reading this correctly then by pushing that switch by the center console will engage front wheel drive only and no drive to the rear?
  13. Oct 10, 2023 at 11:22 AM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Yes, but in order to do that you must remove the rear drive shaft.
    pursuit2550 likes this.
  14. Oct 10, 2023 at 11:24 AM
    coTony
    Tony
    Montrose, CO
    Ok, but who would want to do that? I was thinking that would kick ass being able to do a front wheel dig but not if you have to remove a drive shaft
  15. Oct 10, 2023 at 11:45 AM
    minium
    minium New Member
    Whoosh
    Eurodriver and Sixty9Four20 like this.
  16. Oct 10, 2023 at 11:49 AM
    Black widow TRD
    Manuel
    You’d think it’s common sense….
    minium likes this.
  17. Oct 10, 2023 at 11:56 AM
    Sixty9Four20
    2023 TuRD Pro
    By the way for anyone angry at the Big T for the shenanigans involved in the rear e-locker....
    To achieve rear e-locked mode with only RWD, you would first need to remove the rear drive shaft, then activate FWD switch, then remove the front drive shaft, and finally re-connect the rear drive shaft. Then you should be able to conduct hooligan drift business.
    AZBoatHauler likes this.
  18. Oct 10, 2023 at 11:59 AM
    coTony
    Tony
    Montrose, CO
    Push a button and we are good to go! Never been a fan of the electric locks from the dealer. When you install your own at least you know how the way they work is the way you installed them
