Front wheel bearing failure 2017 Tundra
Discussion in 'General Tundra Discussion' started by tompaj10, Jun 8, 2020.
  1. Jun 8, 2020 at 9:04 AM
    tompaj10
    tompaj10 [OP] New Member
    I have 3rd failure of left front wheel bearing in my 2017 Tundra with 26k miles on it. Dealer will replace wheel bearing but what causes failure??? I afraid about transaxle, soon I will be out of warranty...
    All help highly appreciated...
  2. Jun 8, 2020 at 9:12 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Make sure they are replacing all THREE seals when doing the bearing.
    A lot of places just press a new bearing in and call it a day.
    If the o-ring and both lip seals are not replaced, it will fail shortly thereafter again from water intrusion.
  3. Jun 9, 2020 at 9:59 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I just found out my 19 with 38k miles need both front wheel bearings replaced. None of my other tundras have had this issue, hopefully it’s not a recurring issue.
  4. Jun 9, 2020 at 11:15 PM
    kgb4187
    kgb4187 New Member
    Do you have different wheels or suspension compared to your other Tundras?
    Ruggybuggy likes this.
  5. Jun 9, 2020 at 11:45 PM
    FREEDOMEDIA
    FREEDOMEDIA New Member
    Nate
    2002 TRDOR Accesscab 4x4
    3/2 Bilstein suspension, 285/70R17 Ridge Grapplers on SCS Ray10 Wheels
    Sorry to hear! Sound like a QC issue during manufacturing it so many newer ones are having this issue.
  6. Jun 10, 2020 at 3:02 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    What are the symptoms of this? How did you know you needed it?
  7. Jun 10, 2020 at 6:34 AM
    19crewmaxTRD
    Seth
    Everything on the truck is stock, still on factory tires. I was on my way back from a job and started feeling a small vibration. The vibration starts between 40-50 mph and doesn’t go away until you come to a stop. I thought it was just something stuck in a tire or caught on the bottom of the truck, but could find anything after looking everything over. Took it in to a my local service center and they said the front wheel bearings are both going, and that the left is making more noise than the right.
    Ronin73 likes this.
  8. Jun 20, 2020 at 9:06 AM
    19crewmaxTRD
    Seth
    Got my truck back on Wednesday figured I’d update you guys. Ended up being the rear axle bearings. Covered up warranty but if it eats another set I’ll be looking at new trucks. I always have 500 lbs in the bed of my truck so I expect a little extra wear and tear (decreases brake and tire life, blown out shocks) but my last tundra that was treated the same and only had a rear axle seal fail at 175,000 miles. And I can’t afford for my truck to be down a week at a time, it’s had enough to have it gone for a day for oil changes.
