Front vibration
Discussion in '2nd Gen Tundras (2007-2013)' started by Madmikee, Mar 30, 2018.
  1. Mar 30, 2018 at 12:03 PM
    Madmikee
    Madmikee [OP] New Member
    2007 Tundra 4WD SR5
    Gents, My 2007 4WD SR5 has a slight vibration braking down steep inclines.New brakes, tires and front end alignment all done recently. Thoughts? Thanks
  2. Mar 30, 2018 at 12:13 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    New brakes not broken in properly? I did the brakes on my wife's car a while back and didn't break them in and they fairly quickly developed a "warped" feeling when braking downhill. They weren't warped, but if the pad doesn't get deposited on the rotor evenly it can give you that feeling.
    Stick around, though, as others will probably have better explanations/suggestions!
    Atomic City Tundra and 15whtrd like this.
  3. Mar 30, 2018 at 12:40 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Did you get new rotors with your new brakes? If not did you re-surface them? It sounded like they could be slightly warped.
  4. Apr 5, 2018 at 9:00 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Another vote for properly bedded brakes. It is important that you do it right, and also make sure that you don't come to a complete stop during the procedure. If you do, start over. Also, sometimes you can get a deposit imprint left if you have a sudden hard panic stop. Then you have to repeat the procedure again. Here is a video - long and geared more toward racers, but it conveys the idea, and goes over the procedure for street pads.
    https://www.youtube.com/watch?v=pdPX6rzuINc
    Jermalex and nk1794 like this.
