Front tow hook torque specs please?
Discussion in '2.5 Gen Tundras (2014-2021)' started by trooper669, Jul 23, 2018.
  1. Jul 23, 2018 at 2:54 PM
    trooper669
    trooper669 [OP] New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    2018 1794. Going to paint the front lower tow hooks, but all the research I have done shows bolt torque spect at 43, 63, and 83 ft. lbs. Can anyone provide the CORRECT specs please? I would assume since since the tow bar bolts are 84 ft. lbs, the tow hook bolts should be about the same?
  2. Jul 23, 2018 at 3:03 PM
    trooper669
    2018 1794 MGM
    I think I found the answer. 65 ft. lbs in case anyone needs the correct torque.
    NewImprovedRon likes this.
  3. Jul 23, 2018 at 3:04 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    The TRD Pro skid plate installation instructions say to remove and reinstall the tow hooks. This doc lists the torque as 43 ft-lbf - this is what I used when I painted my tow hooks.
  4. Jul 23, 2018 at 3:49 PM
    trooper669
    2018 1794 MGM
    Thanks. Thats what I mean. I'll go with 43 since the skid plate instructions advised it. Thanks! I'll copy @Roman in this, he should know!
    Roman likes this.
  5. Jul 24, 2018 at 3:33 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I would not be surprised if Toyota had different documents with different torque settings - 43 does seem a bit low.
    joonbug and CaptainGrumpus like this.
  6. Jun 14, 2019 at 3:15 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    BravoDeltaRomeo likes this.
  7. Jun 14, 2019 at 3:27 PM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Nick
    Union, ME
    08 DC SR5
    6 Ugga Duggas and it should be fine
  8. Jun 14, 2019 at 3:38 PM
    Just use a breaker bar like I did....
    CH1NO, Medic343 and (deleted member) like this.
  9. Jun 14, 2019 at 3:56 PM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    Toyota has a spec sheet for the bolts. If the bolts show an 11 on them that means something like 116 ft lbs. google Toyota Standard Bolt Torque Specifications
    JohnLakeman likes this.
  10. Jun 14, 2019 at 4:37 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    I read 65lbft quite a bit. So they got that and a little blue LT.
  11. Jun 14, 2019 at 4:39 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    Now that’s good n tight! Read the chart. If the bolt is 10mm diameter it’s 64lbft, if 12mm diameter then it’s 116lbft. Unless it’s a flange bolt, then it’s more.
  12. Jun 14, 2019 at 5:21 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Different size/class bolts have different torque values. Read the head markings and measure the thread diameter (mm), and I'll be able to tell you Toyota's specified torque value.
  13. Jun 14, 2019 at 5:35 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    If you have a TRD skid Plate it has the specs in the directions and it states replace the four bolts for the tow hooks and torque to 43 ft lb. those directions were with my TRD skid plate With the red TRD on the plate for my truck.
  14. Jun 14, 2019 at 5:44 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    Yea, I read that one as well with a raised eyebrow. Those are good sized bolts and was at or past 43lbft with a standard 1/2” dr ratchet without trying.
  15. Jun 14, 2019 at 6:30 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    The head is marked 11. I’ll have to pull a bolt to tell u the rest.
  16. Jun 14, 2019 at 7:50 PM
    JohnLakeman
    The highest strength class bolt is 11T. Standard bolt chart lists 11T in 8mm, 10mm, and 12mm in either standard hex head or flange head. Torque values for 8, 10, 12 standard hex head is 31, 64, and 116 ft-lb respectively. Torque values for 8, 10, 12 flange head bolts are slightly higher: 35, 72, 130 ft-lb respectively. For comparison, 8mm ~ 5/16", 10mm ~> 3/8", 12mm ~< 1/2".
  17. Jun 14, 2019 at 8:24 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    11 on the head, 12mm diameter and I believe it’s a flange bolt with a washer under the head.
  18. Jun 15, 2019 at 4:42 AM
    JohnLakeman
    The 43 ft-lb spec in the skid plate instructions must be for the skid plate bolts.
    Whoever wrote the text for the instructions must have been confused about torque values if the tow hook bolts are 11T 12mm. (As in...What's a ft-lb?)
    Edit: The head markings ARE IMPORTANT. Class 11T is stronger than US Grade 8. If a metric bolt is only class 4T or 5T, then that 43 ft-lb torque would make sense on a 12mm bolt.
  19. May 9, 2020 at 7:32 AM
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    The instructions are actually Toyota Official instructions...
    http://toyotaparts.sparkstoyota.com/install/PT938-34140inst.pdf
    omgboost and NewImprovedRon like this.
  20. May 9, 2020 at 8:11 AM
    JohnLakeman
    Well, if they're "Official Instructions", I would certainly do exactly what they say...even if it makes no sense from an engineering perspective. If 11T fasteners in a skid plate application are torqued to full torque, I expect the tapped holes they are going into will be be stripped.
    Edit: Toyota standard bolt specs in the SRM call for 130 ft-lbf on a 12mm 11T flanged head hex bolt.
  21. May 9, 2020 at 2:12 PM
    Swatdude1
    Phoenix, AZ
    The five skid plate bolts are only 21 ft.lbs. One of the dealers I had it serviced at stripped one of them out doing an oil change and I didn't know until several oil changes later. Of course none of them would take responsibility for it.
    Good to see that the new TRD one has the access door on it now so you don't have to take it off every time, same as the RCI one I just installed.
  22. May 10, 2020 at 8:31 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    According to Trd skid plate install it’s 43 ft pounds
  23. Jan 11, 2021 at 2:43 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    None that I found. I went to 43 on my 2019. Bolt had a "11" on it and it was a 17mm head for the socket.
    I figure I can always torque them tighter if needed or someone comes up with the one and done number.
  24. Feb 19, 2021 at 4:27 PM
    Mountainmanjh
    Mountainmanjh New Member
    Northern Utah
    2012 Black Crewmax
    Eibach Protruck coilovers and shocks Total Chaos UCAs, bed stiffeners Deaver U748 leaf springs with Camburg shackles TRD sway bars, front and rear Gear Dominator wheels (18x9 18+) Cooper AT3 XLT (275/70r18) RCI engine, trans, and A-arm skids Transferflow 46-gal fuel tank Yakima Outpost bed rack Curt front hitch receiver SumoSprings (yellow) StartX remote start *coming soon* Auburn rear LSD RCI sliders, diff skid, cat guards Coastal offroad front bumper Badlands apex winch Kenwood DNX577S head unit
    The instructions that came with my Curt front-mounted hitch receiver say 79 ft-lbs with the hitch sandwiched between the tow hooks and the radiator cross member, so let's add that spec to the list...
  25. Nov 1, 2021 at 5:52 PM
    clarkritchie
    clarkritchie New Member
    The manual that came with my Draw Tite front receiver says 42 ft/lb, but they also list the bolts as being 17mm when they are, in fact, 19mm. They are stamped 8.8. The majority of opinions on this most ambiguous topic seem to center on 65-68 ft/lb, however, I do like 6 Ugga Duggas.
  26. Nov 1, 2021 at 6:24 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Looks like you can torque it from 48 to 97 ft lbs with target torque being 65.
    Swatdude1 and clarkritchie like this.
  27. Nov 12, 2021 at 12:26 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Do all Tundras come with tow hooks?
  28. Nov 12, 2021 at 12:32 PM
    They should. Yours didnt?
  29. Nov 12, 2021 at 1:16 PM
    GCanuck
    Gary
    BC,Canada
    I have them. Just curious if it had to be an SR5 or better
