Front tires dragging / chirping after 4.5 BDS Lift Install
Discussion in 'Suspension' started by MogwaiBoogie, Apr 13, 2021.
  1. Apr 13, 2021 at 9:30 AM
    MogwaiBoogie
    MogwaiBoogie [OP] New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    Hey Guys and Gals, I wanted to post up a problem and solution I encountered after installing a 4.5 BDS kit on my 2020 4x4 Crewmax. I noticed after the kit was installed that there was a chirping and/or dragging sound coming from the front tires when the steering was at full lock. Kinda like when driving on dry pavement in 4WD. I did some searching and found some similar post about this and realized I needed to talk to David @Coachbuilder1 - Turns out this is a common issue with this (and other) bracket lifts on our trucks and David had just the right solution. That chirping / dragging sound was exactly that, with the tie rods provided by BDS there was not enough travel when at full lock so the outside tire was not at the same turn angle as the inner tire causing the outer tire to drag. The Coach Builder Steering Kit which is essentially a beefier outer tie rod that provides more travel at the joint solved the problem. Thanks again David for taking my call and solving my problem.
    texasrho83, BUGEATER, Cruzer and 5 others like this.
  2. Aug 11, 2021 at 6:30 PM
    Goldnshower
    Goldnshower New Member
    New Jersey
    16 tundra
    The answer I’ve been looking for!
  3. Aug 11, 2021 at 6:38 PM
    MogwaiBoogie
    Justin
    TEXAS
    Gotta love tundras.com!
    Goldnshower[QUOTED] likes this.
  4. Oct 25, 2021 at 3:11 PM
    Goldnshower
    New Jersey
    16 tundra
    Finally received these installing tomorrow! Very excited ha ha
  5. Oct 26, 2021 at 7:46 AM
    MogwaiBoogie
    Justin
    TEXAS
    Nice! Let us know if you get the same results. I have about 6K miles on them now and still working as expected. Still get a little chirp on a fully locked turn but its a night and day difference from what it was.
  6. Nov 2, 2021 at 8:55 AM
    Goldnshower
    New Jersey
    16 tundra
    What a difference! Easy job too! I'm beyond satisfied with this upgrade so glad I found this thread thank you guys
    MogwaiBoogie[OP] likes this.
  7. Feb 17, 2022 at 9:12 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    I have the same issue, you think I could install these on my own? Not trying to spend 400 dollars on labor for something so little
  8. Feb 17, 2022 at 9:25 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    You can easily install them on your own. I did. You'll need an alignment afterwards, though.
  9. Feb 17, 2022 at 9:55 AM
    cementsharktrd
    Demetrio
    Have you found a youtube video maybe of someone installing them?
  10. Feb 17, 2022 at 10:11 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    This is a good enough one:
    https://www.youtube.com/watch?v=sPDompMJCe0
    You'll get instructions as well with the coachbuilder kit. Definitely read through it.
    It's a very beefy tie rod end. And it definitely helped my turning radius and tire wear. Got a better alignment afterwards, too. I still have some chirp when full-cut on certain asphalt, but it's not as bad. Have fun!
    cementsharktrd likes this.
  11. Jul 9, 2025 at 9:37 PM
    assfister55
    assfister55 New Member
    Johnny
    Kremmling, Colorado
    '15 Tundra 1794
    6" zone lift. cold air intake. MBRP dual exhaust. 35x12.5 R20 Fuels
    THREAD RESURECTION!!! I'm having the same problem. Bought my truck with a Zone 5" kit already installed with Bilstein front coilovers at their lowest setting (+0.75") so basically a 6" lift. The front tires fight eachother in a parking lot when I'm turning... I'd guess more than 50% steering travel. I had the truck aligned a few weeks ago so that's fine. Could this be the product that fixes the issue? Sounds like it is but I'd like anyone else's feedback/experience. Says you gotta drill out the knuckles too for the ends to fit. Thanks!
