front tires don't spin in 4wd
Discussion in '1st Gen Tundras (2000-2006)' started by Averyklinnnn, Jun 10, 2025 at 6:59 PM.
  1. Jun 10, 2025 at 6:59 PM
    Averyklinnnn
    Averyklinnnn [OP] New Member
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    front diff actuator functions good
    but my front tires in 4wd have no power any ideas
  2. Jun 10, 2025 at 7:01 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Does the front driveshaft spin when in 4wd? That will tell you if the transfer case is working.
  3. Jun 10, 2025 at 7:11 PM
    Averyklinnnn
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    just put a new used transfer case on it and it spins driveshaft
    JasonC. likes this.
  4. Jun 10, 2025 at 7:15 PM
    Jack McCarthy
    Bill
    North of Boston
    Then somehow the front actuator isn’t doing its job if it’s functioning. Could be something internal to the differential itself.
    Out of my zone of expertise.
    BroHon likes this.
  5. Jun 11, 2025 at 2:09 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  6. Jun 11, 2025 at 7:22 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Have you jacked the truck up and verified neither wheels are spinning when the truck is in 4WD? If you're stuck in 4WD, the differential will only send power to one wheel because it is an open differential. This is what people refer to as one wheel peel. Since the front differential is open, the front wheels spin independently. The wheel with the least amount of resistance/ traction will spin while the other is freewheeling.
    You will have to disconnect the rear driveshaft from the transfer case if you jack the front of the truck up to test whether your front wheels turn in 4WD.
