Front tire is rubbing sway bar after lift. What to do?
Discussion in '3rd Gen Tundras (2022+)' started by Bogibbes, Sep 3, 2024.
  1. Sep 3, 2024 at 6:34 PM
    Bogibbes
    Bogibbes [OP] New Member
    Bo
    2024 Tundra TRD
    After installing the Dobinsons MRR 2" coilovers, I now have some rubbing of my front driver's tire in the sway bar when at or near full lock. I've had an alignment done and that didn't improve anything. I'm drinking the 20" TRD OR wheels with 35 x 12.5 Toyo AT3's.
    Other than changing to a smaller wheel and tire combo and/ or removing the sway bar, is there anything that can be done?
  2. Sep 3, 2024 at 6:48 PM
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    spacers to push the wheels out a bit?
    BlackNBlu likes this.
  3. Sep 3, 2024 at 6:52 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
  4. Sep 3, 2024 at 7:20 PM
    lapoolboy
    lapoolboy New Member
    Just roll with it. Rubbing at full lock is no big deal.
    Blufin, Hella Krusty and Badknees like this.
  5. Sep 3, 2024 at 7:34 PM
    Bogibbes
    Bo
    2024 Tundra TRD
    It feels so wrong, though!
    jhtram likes this.
  6. Sep 3, 2024 at 7:35 PM
    lapoolboy
    Nah. FYI, I have 3" lift on OEM 20" TRD wheels with 35x11.50 and still rub.
    Hella Krusty likes this.
  7. Sep 3, 2024 at 10:46 PM
    blenton
    blenton New Member
    Tire pressure? My 275/70R18's would occasionally rub the skid or sway bar (don't remember which) if they were aired down. Aird up to appropriate PSI and no more rub.
  8. Sep 4, 2024 at 4:49 AM
    Bogibbes
    Bo
    2024 Tundra TRD
    As of two days ago they were at 38-40psi.
    I might try the spacer route. From what I've read,as long as you get a quality spacer that is installed correctly, and not overly large, they're fine to use. I'm not ready to get a new tire and wheel setup right now.
  9. Sep 4, 2024 at 7:47 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    Everyone has their own priorities but there's no way I could live with that on a daily driver. Scrubbing makes a truck feel cheap.
  10. Sep 4, 2024 at 7:59 AM
    lapoolboy
    LOL. It barely touches only in forward and only at full-lock holding the steering wheel all the way over. My truck has 12k miles on it and I can count on one hand how many times it's happened and I even noticed. Sway bar doesn't even have the paint rubbed off
  11. Sep 4, 2024 at 8:10 AM
    Tartar88
    Tartar88 New Member
    Steven
    24 trd pro
    Westtcot lift 37s
    Are you a pro? I have seen guys put the pro swaybar on and it has different angles so you can clear tires a lot better.
  12. Sep 4, 2024 at 9:12 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Bogibbes[OP] likes this.
  13. Sep 4, 2024 at 11:31 AM
    Bogibbes
    Bo
    2024 Tundra TRD
    That's where I'm at. It's a $65k truck that I just put a $3000 suspension on and the rubbing sucks. I use full lock all the time since the turning radius is abysmal.
    PlatinumPro[QUOTED] likes this.
  14. Sep 4, 2024 at 12:23 PM
    PlatinumPro
    Yup... I can't ignore that janky lurching feeling either.
    The advice you got above is where i'd go. Spacers/wheels should take the rubber off the sway bar but even with spacers you may be still be forced to adjust the liners in front of your tires to make more room for the taller/wider tire.
    Bogibbes[QUOTED][OP] likes this.
  15. Sep 4, 2024 at 3:33 PM
    Bogibbes
    Bo
    2024 Tundra TRD
    So I did a little more investigating and the driver side tire is actually rubbing against the UCA. I'm not sure if that makes the issue better or worse, or changes the possible solution.
  16. Sep 4, 2024 at 3:55 PM
    Bogibbes
    Bo
    2024 Tundra TRD
    If i go with wheel spacers, how do I know how much space I need to add? I only want to add just enough to eliminate the rub and avoid excess poke.
    Will adding spacers necessitate another alignment?
  17. Sep 4, 2024 at 5:08 PM
    Hella Krusty
    Hella Krusty New Member
    My 2012 rubbed for a decade......
    Blufin likes this.
  18. Sep 4, 2024 at 5:12 PM
    lapoolboy
    Wheel spacers will get you off the UCA and into the fender and/or fender liner and/or mudflaps. It's a can of worms really.
  19. Sep 4, 2024 at 6:03 PM
    BlackNBlu
    Rich
    MN
    If you go through that post I linked earlier, there was an example where a 1" spacer on TRD OR wheels brought the tires out flush to the edge of the wheel arch. I don't recall if that was with stock sized tires or larger.
    Obviously, a bigger tire will equal more poke, all else being the same.
    The space/design constraints of the type of spacer you want (hub-centric and bolt-on) will mean that the smallest you can go is 1" (or 25mm) thick. I have seen 20mm wheel spacers (roughly 3/4") of the same type, but not for our application. There are places that will build them to order. That thin of a spacer will guarantee you will need deep clearance pockets in the mounting hub of your wheels, shortened lugs, or both. I've done both to make them work properly.
    The two brands that come up most frequently are Spidertrax and Bora. Either of those in 1" would be a bolt-on solution, except for....
    What @lapoolboy said above is absolutely valid. There is no free lunch. You push the wheels/tires out and away from rubbing hard parts on the IN-side, now you're likely going to be rubbing soft parts on the OUT-side.
    Pick your poison and deal accordingly.
    I can't answer the alignment question other than to say....maybe.
    My own experience using spacers would lead me to say no.
  20. Apr 16, 2025 at 6:37 AM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Old thread but I’m having the same issue after putting 37” tires in my Tundra.
    Does anybody know if putting the TRD Pro sway bar fixes the sway bar rubbing problem?
  21. Apr 16, 2025 at 10:09 AM
    PlatinumPro
    i've seen a thread for 37's in here which is the crew i'd be looking for advice from. I'm ignorant to how a tire that large sits on the 3rd gens but i do know that with the 2.5 gen Tundras that is the starting point where it can take more than just adding more lift, poke, removing flaps and tucking liners.
    ramnj[QUOTED] likes this.
