Front swaybar and skidplate
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TRDTundra, Mar 28, 2019.
  1. Mar 28, 2019 at 6:28 PM
    TRDTundra
    TRDTundra [OP] New Member
    Jon
    Airdrie, Canada
    2014 SR5
    Hey there, does anybody know if the front TRD swaybar can be installed if you have the aftermarket skidplate as well?
  2. Mar 29, 2019 at 9:26 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Yes it can be installed with aftermarket skid plate. The TRD sway bar is the same diameter as the stock sway bar, just more solid and heavy. You will need to remove the skid plate for the install though.
  3. Mar 29, 2019 at 10:05 AM
    TRDTundra
    Jon
    Airdrie, Canada
    2014 SR5
    Great! Thanks, will be putting one on.
