Front sway bar
Discussion in '2nd Gen Tundras (2007-2013)' started by Yergonzo, Jun 29, 2021.
  1. Jun 29, 2021 at 9:50 PM
    Yergonzo
    Yergonzo [OP] New Member
    Just put on rear sway bar for 2011 Tundra SR5 double cab 2wd lifted 3" in front 1" rear. The results were great!. Am now considering a front sway bar for even more stability. Parts guy
    at Toyota says, " TRD front sway bar not compatible with my truck. "
    Has anyone with 2nd Generation Tundra been able to install a front sway bar? Or is it worth
    pursing..............
    Yergonzo
  2. Jun 29, 2021 at 9:53 PM
    Nando_TRD760
    Nando_TRD760 New Member
    Pasadena CA
    I have a sway bar for sale if interested. Mine should fit the 2007-2021 Tundra. I have the TRD black one for sale. The red one is the one that comes in the Tundra Sport edition.
  3. Jun 29, 2021 at 10:05 PM
    Yergonzo
    Nando_TRD76,
    If I'm not mistaken the TRD black is the hollow bar 17lbs. that is provided in OEM Tundra's. The red TRD is solid approximately
    30lbs. Since the chassis are the same on the 2nd and 3rd generation I don't see why there is a compatibility issue.
    07 Tundie likes this.
  4. Jun 30, 2021 at 1:36 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    81 TOY likes this.
  5. Jun 30, 2021 at 7:04 PM
    Yergonzo
    e30cabrio,
    Thanks for the tip. I saw the video of someone putting one on with that same part number. These Toyota part guys can't think
    out of the box.
    Your rig sounds pretty nice................
  6. Jul 2, 2021 at 4:45 PM
    LillDragun
    LillDragun New Member
    well now...I guess i need to be matchy matchy with my rear bar!
  7. Jul 4, 2021 at 8:57 AM
    Mrencz
    Mrencz New Member
    2008 Tundra Limited Double Cab TRD Offroad
    He’s probably saying that because you lifted the front up 3”. I just did a 3”/2” on my 4wd 2008 tundra limited. The kit came with brackets to drop my sway bar down for it to have the right fit. You should not have an issue installing the sway bar if you get the spacers. Mine are from ReadyLift.
    Yergonzo[OP] likes this.
  8. Jul 4, 2021 at 9:08 AM
    TheBeast The Beach
    what one should expect from switching from the black sway bar to the trd spot front sway bar ? I have been looking at it as well.
  9. Jul 4, 2021 at 9:03 PM
    Yergonzo
    Mrencz,
    Thanks for the tip. What ReadyLift kit specifically do you speak of. I ordered the sway bar but did not consider brackets to
    compensate for the 3" lift. Having just installed the rear sway bar I was struck by how planted to truck felt.
    Thanks
  10. Jul 5, 2021 at 5:03 AM
    Mrencz
    Mrencz New Member
  11. Jul 5, 2021 at 7:10 PM
    Yergonzo
    Mrencz,
    Completed the lift last fall. I ordered the Front Sway last week and the brackets yesterday so I don't expect any problems
    especially since my truck is a 2011.
    Appreciate your input...........
    Yergonzo
  12. Jul 5, 2021 at 7:12 PM
    Not all lifts require the sway bar drop down kit. Ready lift does, Toytec coilover lift does not.
  13. Jul 5, 2021 at 7:16 PM
    There is not a TRD branded black sway bar. It's a stock OEM bar, which is hollow and weighs 17 lbs. The TRD is solid and weighs 30 lbs. @TheBeast, it makes the steering fill a little more firm. I have had mine for a couple of years now.
    TheBeast likes this.
  14. Jul 5, 2021 at 7:25 PM
    Yergonzo
    With the rear coupled with the front sway bar, I expect the Ridge Grapplers to glide through offramps and turns
    with precision.
  15. Jul 6, 2021 at 9:20 AM
    Nando_TRD760
    Pasadena CA
    What you talking about? The black one came on my Limited 4x4 TRD Off Road package. The RED one comes in the sport Tundra's.
  16. Jul 6, 2021 at 11:59 AM
    All 07 and up have the black one. The red TRD is the upgrade.
  17. Jul 6, 2021 at 12:09 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    TRD Off Road package uses the OEM sway bar. Not a TRD branded one. Just like the skid "plate" on the Off Road package has nothing to do with the TRD skid plate that is 1/4" thick aluminum.
    Ktate likes this.
  18. Jul 6, 2021 at 12:12 PM
    +1
  19. Jul 6, 2021 at 12:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The TSS comes with LT rated tires right. Thats some truck ride right there
