Front Sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Richard913, Dec 9, 2015.
  1. Dec 9, 2015 at 7:54 AM
    Richard913
    Richard913 [OP] New Member
    Rich
    2015 Tundra TRD Pro - Inferno
    Stock
    Anyone ever install a sway bar in a Tundra TRD Pro that was intended for a Sequoia?
  2. Dec 9, 2015 at 9:57 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've only replaced the standard sway bar with the Sequoia bar. What's your motivation/what're you considering here?
  3. Dec 9, 2015 at 10:41 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    @jberry813 has a Sequoia front and a TRD rear on his Platinum.
    jberry813 likes this.
  4. Dec 9, 2015 at 10:45 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Indeed I do have both the Sequoia front and TRD rear. Highly recommend for anyone who's lifted their truck and enjoys spirited driving...or lots of towing.
    Sefferston likes this.
  5. Dec 9, 2015 at 10:55 AM
    Richard913
    Rich
    Stock
    Truck is pretty heavy when loaded and there is a good amount of roll. Figured it could get alot better.
  6. Dec 9, 2015 at 10:56 AM
    Richard913
    Rich
    Stock
    What kind of lift do you have? I am not changing out mine, just looking for a more stable ride.
  7. Dec 9, 2015 at 10:59 AM
    jberry813
    Lake Tahoe
    King Coilovers set at 3" and TC 3/4" rear shackle.
  8. Dec 9, 2015 at 11:01 AM
    Richard913
    Rich
    Stock
    I am not a lift guy, but that sounds like it could be pretty much what the Pro's come with. Thanks
  9. Dec 9, 2015 at 11:07 AM
    jberry813
    Lake Tahoe
    Apples and oranges. The TRD Pro is a 2" front lift and has softer rear leafs.
  10. Dec 9, 2015 at 11:56 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    How much bigger is the sequoia bar from the tundra?
  11. Dec 9, 2015 at 12:02 PM
    jberry813
    Lake Tahoe
    It's not bigger. Same OD, but smaller ID. 16% stiffer.
  12. Dec 9, 2015 at 8:04 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Said the prostitute to the other prostitute
  13. Dec 9, 2015 at 8:21 PM
    jberry813
    Lake Tahoe
    You must have some interesting whores in Colorado.
    Black Wolf and Sefferston like this.
  14. Dec 9, 2015 at 9:23 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    I have a Platinum with TRD Pro suspension and Sequoia front/TRD rear sway bars. It handles great! Highly recommended.
  15. Dec 10, 2015 at 4:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    In my experience, adding the rear sway bar (TRD in my case) made the greatest difference. Adding the Sequoia bar made a difference, but it was more subtle. I don't know if the bar on the Pros is different from the standard and Sequoia ones. Looking up part numbers may gain you some insight. I've can't think of any occasion where I've read of anyone removing their Pro bar for the Sequoia bar, only about removing the standard one.
  16. Dec 10, 2015 at 6:37 AM
    jberry813
    Lake Tahoe
    Completely agreed on the TRD rear making a larger difference than Sequoia front. But the TRD Pro suspension is just different coilovers, rear shocks, and rear springs. All 2nd/3rd gen Tundras have the same front sway bar.
  17. Dec 10, 2015 at 9:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So, as far as we know, barring (ha) anything unforeseen, the OP should be able to directly swap in the Sequoia bar if he so desires?
  18. Dec 10, 2015 at 10:05 AM
    jberry813
    Lake Tahoe
    Its a fact, not opinion. It will replace just as any Tundra.
  19. Dec 10, 2015 at 10:29 AM
    In your experience, would it be best to go with both front/rear Tundra sway bars or one Tundra and one Sequoia? I know there's not much of a difference, but would it be noticeable one vs the other?
  20. Dec 10, 2015 at 10:31 AM
    jberry813
    Lake Tahoe
    If you have the extra $130 bucks, do both. Otherwise just do the rear. Most my excessive body roll issues went away with the rear. The Sequoia front was marginal.
    But I drive like an asshole and I live in the mountains.
  21. Dec 10, 2015 at 2:31 PM
    pvmike
    Los Angeles
    I drive like an asshole too, so I felt like it made a difference with reducing understeer.
  22. Dec 12, 2015 at 5:52 AM
    chphilo
    chphilo Tundra addict
    Western PA
    For fast street driving, stiff sway bars will help you in handling. For serious to semi-serious off-roaders, adding a stiff bar makes your truck less capable. There are some off-roaders who took the entire front sway bars off from their Tundras. They claim their trucks perform a lot better off road without the front sway bars.
    I don't go off road, but I live in an area with very rough roads with a lot of cracks and pot holes. That was the reason why I got an off-road suspension, off-road tires, and no rear sway bar. Some people recommended that I take off the front sway bar, but since I don't off road, that will be going too far, I decided. It really depends what you use your truck for.
  23. Dec 12, 2015 at 9:19 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I went with Hellwig's (rear) swaybar for my 2010. Didn't like TRD's red color and Hellwig's are thicker.Really improved handling,more so than I thought it would.:thumbsup:
    FA141794 likes this.
  24. Jan 12, 2016 at 11:09 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I have the SR5 ordered with the level kit option to be installed, I ordered the rear sway bar by recomendation. Should I order a front sway bar? I want a smoother ride, not to worried about body roll I just want more comfort.
  25. Jan 13, 2016 at 10:39 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The sway bar is to control body roll. It won't really smooth out the ride in the way that I think you're thinking, that'd be more of a shock/spring thing.
  26. Jan 24, 2016 at 7:58 AM
    pauloantonio
    pauloantonio New Member
    What is a good price for a used Sequoia SB? Was thinking about heading to the junk yards to see if they have one.
  27. Jan 24, 2016 at 8:33 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suppose that anything less than $100 would be reasonable.
  28. Jan 24, 2016 at 11:04 AM
    Tracker
    Tracker New Member
    Shane
    Since I don't have my truck yet does the tundra not have a front sway at all?
  29. Jan 24, 2016 at 11:57 AM
    The Pro might? I'm not sure. U can get a Tundra sway bar though.
  30. Jan 24, 2016 at 1:24 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The sway bar on the Sequoia is stiffer, as it's a bit heavier. The sway bar that comes on all Pros isn't any different than what's on the standard Tundra.
