Front sway bar delete
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra174x4, Feb 16, 2020.
  1. Feb 16, 2020 at 3:49 AM
    Tundra174x4
    Tundra174x4 [OP] New Member
    Cody
    2017 tundra sr5 trd off-road 4x4
    Hey guys, Just installed stage 4 ICON suspension on my 17 Tundra. Should i remove my front sway bar now??? I live in the desert and am in the dirt at least once a week. Whats your take??
    Rica25 and Mountun Goat like this.
  2. Feb 16, 2020 at 4:28 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Yes. Unless you dont want to get the maximum from all the $$ you just put into your suspension.
  3. Feb 16, 2020 at 4:46 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Undo it on both side of ther links, push it up and tie it with three bungee. So, when you think you need it again it's still the just need to bolt it back up.
    JPB_VT, Toyotoholic, Rica25 and 3 others like this.
  4. Feb 16, 2020 at 5:39 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    Remove it! I removed mine the other day and it was night and day. Can't believe how soft the ride is now....and I have a spacer lift.
  5. Feb 16, 2020 at 9:47 AM
    Tundra174x4
    Cody
    Awesome thanks for the feedback guys. I’m guessing I’ll have to take off the skid plate to slide it out lol
    Rica25 likes this.
  6. Feb 16, 2020 at 9:55 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I got my bar off without removing skid plate in pretty sure. At most I loosened front bolts or took just front bolts off of skid it’s night and day.
    Rica25 likes this.
  7. Feb 16, 2020 at 10:26 AM
    The ride is softer with it off? I have the Readylift 3/2 and the TRD bar on the front and rear.
    Rica25 likes this.
  8. Feb 16, 2020 at 11:25 AM
    Nm6300'asl
    2022 DC SR5 4x4
    With the swaybar transfering energy to the opposite side it is "preloading" the springs even more than just spacers. When the bar is removed it almost feels like the spring rate is lighter.
    Hbjeff and Rica25 like this.
  9. Feb 16, 2020 at 1:01 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Would it make a difference with 5100’s on top setting?
    Rica25 likes this.
  10. Feb 16, 2020 at 1:04 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    This.
    Rica25 likes this.
  11. Feb 16, 2020 at 1:05 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Yes. I am on 6112 and no sway bar, last truck 5100 and no sway bar, truck b4 spacers and no sway bar
    Rica25 and JMB like this.
  12. Feb 16, 2020 at 1:10 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    It will give you better travel/independent articulation. It will also change the body lean in corners.
    Rica25 likes this.
  13. Feb 16, 2020 at 1:22 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Will it lean more? Now with 5100’s top setting, it rides stiff and doesn’t lean in corners. I’d like a little softer ride out of these
    ben15 and Rica25 like this.
  14. Feb 16, 2020 at 3:23 PM
    JLS in WA
    Not a tundra, but I broke both sway bar links on my Dodge 2500. For lack of technical terms, I could feel more lean and a softer feel in the front end around corners.
    Rica25 likes this.
  15. Feb 17, 2020 at 12:03 AM
    Tundra174x4
    Cody
    Just took it off!! Body roll not nearly as bad as I thought
  16. Feb 17, 2020 at 3:08 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Is the ride better?
    Rica25 likes this.
  17. Feb 17, 2020 at 10:19 AM
    Tundra174x4
    Cody
    Definitely feels softer up front, I did notice it was a bit more wobbly up front lol that may be my imagination though. Overall I’m happy with it off
    Rica25 likes this.
  18. Feb 17, 2020 at 1:08 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Take it off. The ride quality will improve a lot. And it will articulate way more Offroad. I had mine off on my tacoma for like 25,000 miles after i was complaining about the lift harshness and someone mentioned it would help
    Rica25 likes this.
  19. Feb 17, 2020 at 2:56 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Just took it off. Rides like a caddy now! Can tell any real difference in body roll and still feels planted.
    Worst part..... putting the skid plate back on. And I thought the one on my ‘04 was a pita....
  20. Feb 17, 2020 at 6:42 PM
    codename607
    Chicago
    2024 Tundra
    Yes, the ride is much smoother. Just remove yours and test it out.
    Rica25 likes this.
  21. Feb 17, 2020 at 7:17 PM
    JLS in WA
    How does it do around corners with bumps?
    In all fairness, my evaluation was apples to oranges because it was a solid axle front end with a heavy Diesel engine.
    Rica25 likes this.
  22. Feb 17, 2020 at 7:59 PM
    ZPMAN
    Minnesota
    If someone had more time than me they could make up a sway bar that you could disengage pins manually or possibly with a 12v solenoid. One thing might be to overcome would be the strength of the weld to the hardened steel of the sway bar. If it hasn't been done already. 20200217_224407.jpg
    Rica25 and Tundyfundy like this.
  23. Feb 17, 2020 at 8:36 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    So someone mentioned unbolting and securing the end links out of the way, what if you made some pins for the end that lock in the end links with say, a cotter pin for fast reconnect?
    Rica25 likes this.
  24. Feb 17, 2020 at 8:41 PM
    ZPMAN
    Minnesota
    But it would be so nice to just to flip a switch and presto no sway bar.
    Tundyfundy and Rica25 like this.
  25. Feb 17, 2020 at 8:55 PM
    ZPMAN
    Minnesota
    One other thing besides curing cancer I would like to do is find a way to find a simple way to modify (increase volume) on the OEM head unit for the JBL sound system's, I'd make millions.
    :spending:
    JPB_VT and Rica25 like this.
  26. Feb 18, 2020 at 4:56 AM
    codename607
    Chicago
    2024 Tundra
    You do get some body roll when cornering. I can still take turns as fast as I want tho. Didn't feel like it was bad enough to put the sway bar back on. I also carry a 1000lbs of gear(camper) in my truck at all times.
  27. Feb 18, 2020 at 5:46 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    I was a bit skeptical but I am glad I took it off. Bilsteins on top setting without the sway bar rides, to me, better than stock
  28. Feb 18, 2020 at 5:50 AM
    codename607
    Chicago
    2024 Tundra
    Did you have the stock sway bar or the TRD version?
  29. Feb 18, 2020 at 6:06 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I want to try this but I heard it’s dangerous to take it off. I do have Icon coilovers though
  30. Feb 18, 2020 at 6:28 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Stock sway bar. I will be adding the TRD Rear bar soon
