Front skid plate upgrade.
Discussion in 'General Tundra Discussion' started by Rex Kramer, Sep 30, 2019.
  1. Sep 30, 2019 at 6:33 AM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    What are my options for a new skid plate that has the oil filter change door?
    2007 2WD
    Thank you.
  2. Sep 30, 2019 at 6:37 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    RCI and TRD are two.
    Many have just cut out a square hole in the stock one. Some have saved the cutout, hinged and buckled for a door.
    15whtrd and Rex Kramer[OP] like this.
  3. Sep 30, 2019 at 8:12 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    check out RCI's instagram page, lots of pics
  4. Sep 30, 2019 at 8:14 AM
    Rex Kramer
    Georgia
    I like their product, and emailed them about their scratch & dent, blem skid plates for my application.
  5. Sep 30, 2019 at 10:12 AM
    Rex Kramer
    Georgia
    RCI is out, they don't make a front SP for 2WD.
  6. Sep 30, 2019 at 10:14 AM
    15whtrd
    15whtrd Mr. Blonde
    That seems strange. You have the stock metal one correct? If so, I don’t see why the RCI wouldn’t bolt up in the same location.
  7. Sep 30, 2019 at 10:16 AM
    Trooper2
    JR
    Kind of what I was thinking; the stock SP is common for 2WD and 4WD.
    15whtrd[QUOTED] likes this.
  8. Sep 30, 2019 at 10:30 AM
    Rex Kramer
    Georgia
    Their reply to my email.
    Trooper2 and 15whtrd like this.
  9. Sep 30, 2019 at 11:38 AM
    Trooper2
    JR
    Maybe they do and just do not know it, LOL.
    If really interested, confirm toyota part numbers, 2wd vs 4wd. If same rci should work for you.
    @Roman
  10. Sep 30, 2019 at 1:29 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    TRD skid plate fits both 2WD and 4WD. :notsure:
    Rex Kramer[OP] and 15whtrd like this.
  11. Sep 30, 2019 at 1:32 PM
    I would call RCI and ask for Josh. Their skid should fit.
  12. Sep 30, 2019 at 1:40 PM
    Trooper2
    JR
    Thanks! Aftermarket vendor saying their Skid Plate only fit 4WD. Doesn't make sense....
    Roman[QUOTED] and 15whtrd like this.
  13. Sep 30, 2019 at 1:49 PM
    15whtrd
    15whtrd Mr. Blonde
    @RCIoffroad might sell a few more if they could give definitive answers as to why it doesn’t fit. I tried looking it up and I have seen the question asked a couple of times but no answer. I did see somewhere that it said it takes modifications. The skid plate mounts to the crossmember with a couple of carriage bolts and large washers. Then it has the standard mounting points that the oem skid plate uses. As well as bolts to mount the front bumper plastic to it. I can only think the only difference would be possibly the crossmember.
    Rex Kramer[OP] and Trooper2 like this.
  14. Sep 30, 2019 at 1:54 PM
    Trooper2
    JR
    It is heavier and may require more support. Maybe the 4wd crossmember is different than 2wd.
    Black Wolf and 15whtrd[QUOTED] like this.
  15. Sep 30, 2019 at 1:55 PM
    15whtrd
    15whtrd Mr. Blonde
    That or maybe it has different holes for mounting or is it a slightly different location because of the transfer case. I’m just guessing here LOL
    Trooper2[QUOTED] likes this.
  16. Sep 30, 2019 at 2:39 PM
    Roman
    Roman
    Franklin, TN
    Front two cross members are the same part number.
    15whtrd, Black Wolf and Trooper2 like this.
  17. Sep 30, 2019 at 4:22 PM
    My guess is that RCI hasn't had a 2WD tunny in for front skid fitment yet even though it may be identical. RCI started out fabbing skids and sliders for the Colorado 4X4 FJ and 4R community and did quite well. RCI only recently in the last couple years moved to making armor for the Tundra. Eventually I'm sure a slider will be made for the DC. Who knows, might be in work already. The powers that be there do realize that many of us are rigging up our full size trucks for hitting some trails. Once again I recommend calling RCI directly.
