Front, Rear Differentials and Transfer Case oil
Discussion in '2nd Gen Tundras (2007-2013)' started by vjb, Mar 11, 2024.
  1. Mar 11, 2024 at 10:22 AM
    vjb
    vjb [OP] New Member
    V.J.
    Idaho
    2011 Tundra Limited 4x4 5.7L
    Installed Bilstein 5100 shocks front & rear. Front set at first ring (0.85"). Attempting to get this 2011 Tundra off-road ready.
    I have a 2011 Tundra Limited 5.7L and want to know if anyone has used "Ravenol" Synthetic oils for their differentials and/or transfer case and if so how has it worked for you?
    Ravenol has a kit for the Tundra (2007-2012) that includes the differential oil, front & rear (SAE 75W-85 API GL-5) gear oil and Transfer Case oil (SAE 75W-90 API GL-5) which I'm thinking about using. Thanks in advance.
  2. Mar 11, 2024 at 10:26 AM
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    Lots of trucks on here running Ravenol. I have it in my transfer case and no problems so far.
  3. Mar 11, 2024 at 10:28 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I had problems with Toyota oil in transfer case in winters. Gone after replacing with Ravenol, it shifts in and out reliably.
  4. Mar 11, 2024 at 1:15 PM
    vjb
    vjb [OP] New Member
    V.J.
    Idaho
    Thanks
