Front/rear differential and transfer case
Discussion in 'General Tundra Discussion' started by 4tBeta, Feb 23, 2023.
  1. Feb 23, 2023 at 4:50 PM
    4tBeta
    4tBeta [OP] New Member
    2015 Toyota Tundra SR5
    Okay guys I'm asking you guys cuz you guys are the pros but please don't say there's threads that talk about this and my answer is in one of the threads yeah I've read them all it's just a bunch of guys going back and forth back and forth back and forth about what they should use and what you should use and what you can use and what this guy said with that guy says I want to know legit what you guys are using for front and rear and transfer case thanks in advance guys I appreciate it
  2. Feb 23, 2023 at 4:56 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Mr Badwrench likes this.
  3. Feb 23, 2023 at 5:03 PM
    blenton
    blenton New Member
    Used fry oil and bacon grease. Does wonders. Doesn’t smell bad when you change it.
    hagrid, Piki and JLS in WA like this.
  4. Feb 23, 2023 at 5:04 PM
    Mr Badwrench
    Mr Badwrench New Member
    Is the Ravenol better for faster 4X4 switching? My 2001 goes into 4X4 in seconds in sub-zero weather consistently with the cheap Tractor Supply oil that I dumped in. My 2018 takes f o r e v e r with the factory lube and I don't want to make it worse.
  5. Feb 23, 2023 at 6:53 PM
    BlueRibbon4x4
    Geno
    I heard Ravenol is thinner and has additives for gears or some kinda mumbo jumbo. Toyota used 75w, so I used 75w.
    Mr Badwrench[QUOTED] likes this.
  6. Feb 23, 2023 at 7:01 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    Soupbean77 likes this.
  7. Feb 23, 2023 at 7:08 PM
    Mr Badwrench
    Does it actuate pretty fast in colder temps?
    Sometimes I need to use 4x4 at intersections or stoplights and it takes about 10 seconds to engage (or three attempts) which seems like an eternity.
  8. Feb 23, 2023 at 7:18 PM
    blenton
    blenton New Member
    When was the last time you changed the oil in the transfer case?
    BlueRibbon4x4 likes this.
  9. Feb 23, 2023 at 7:48 PM
    Mr Badwrench
    It's original, about 40k miles.
  10. Feb 23, 2023 at 7:58 PM
    BlueRibbon4x4
    Geno
    I did my first change at 60k. When changing into 4Hi, your truck should be moving. I think it may switch over while still, but I’m always moving when I hit the switch. Switches right over. 4Lo is where you should be at a stop, in neutral.
  11. Feb 23, 2023 at 10:06 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’ll buy some punctuation plz…
    hagrid and Terndrerrr like this.
  12. Feb 23, 2023 at 10:13 PM
    4tBeta
    Okay thanks Blue ribbon I appreciate it
  13. Feb 23, 2023 at 11:27 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Lol, so you read all the threads with people going back and forth about what they use and recommend and decided to start another one?
    Under 2014 75w90 all three
    Over 2014 75w85 or 75w90 in front and rear and 75w in the transfer case. The only actually approved fluid is Toyotas fluid, part number 08885-81080. Others on the forum have also used Ravenol 75w, Royal Purple Syncromax, Redline LV, and even regular old 75w90.
    Your thread will now be one more of these same exact threads with the same exact information regurgitated over and over again.
    omgboost, Piki and BlueRibbon4x4 like this.
  14. Feb 24, 2023 at 6:20 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    This is always very simple:
    1) Read the manual.
    2) Do what it says.
  15. Feb 24, 2023 at 6:37 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    So we can have another one where everyone goes back and forth. Brilliant! Guess I’ll add my same blurb to this thread that I posted in all the others. :rofl:
    I am on team 75W for 2014-2021 because that is the proper weight spec’d for the new and entirely different transfer case that went into the Tundra in 2014. I read a ton of stuff on BITOG forums and found that 75w90 is 3-4x thicker at operating temp than 75W. Have people run 100k with the wrong weight oil and been ok? I suppose so. But my plan is to keep this truck far longer than that, so I’m sticking with what is spec’d in the manual. And unlike engine oil, the 2014-2021 transfer case does not have an acceptable range of oil weights listed in the manual.
    I did use Ravenol because it’s cheaper. My thinking is that the correct weight matters more than the brand.
    If you have your drain and fills done at the dealer, you should expect that they are using the cheapest bulk 75w90 for both diffs and TC they can find, even if the service order has the OEM part numbers (and prices :evil:) listed.
  16. Feb 24, 2023 at 7:46 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    I use RedLine 75w90 front and back and 75w85 for the transfer case. Changed at 40K and no drop in mileage or issue switching in/out of 4. I do try to switch it in/out of 4 one week even if it's just in a gravel parking lot at work. It feels like it shifts slightly faster than the original oil.
  17. Feb 24, 2023 at 7:48 AM
    CTundraForMe
    CTundraForMe New Member
    Amsoil severe for diffs.
    Genuine Toyota oil in a tin can for transfer case.
  18. Feb 24, 2023 at 8:51 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Shell GADUS NLGI-00 for diffs.
    Kubota SUDT2 in non-biodegradeable gallon jugs for X-fer case.
    JLS in WA and des2mtn like this.
