Front lower shock bushings?
Discussion in '1st Gen Tundras (2000-2006)' started by nickrick78, Apr 19, 2021.
  1. Apr 19, 2021 at 5:00 PM
    nickrick78
    nickrick78 [OP] New Member
    Nick
    Pittsburgh PA
    2004 DC
    Anyone replace these? I can't find a listing on the parts. Should be a replaceable part instead of doing the whole strut assembly.
    If anyone has done this do you have a part number?
  2. Apr 19, 2021 at 5:33 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Yeah, the part exists. I did it once on one shock. Something like $20 plus another $20 to press out the old and put a new one in as I recall. Not by Toyota though.
    Had to get the shock bushing from Bilstein. The one for Toyota’s Bilstein off road shock fit the regular stock shock as well.
  3. Apr 19, 2021 at 6:18 PM
    Jack McCarthy
    Bill
    North of Boston
    Go here and read about my pain. The shock bushing for the Bilstein 4600s fit the stock Tokico shock.
  4. Apr 19, 2021 at 7:04 PM
    If the bushing needs to be replaced due to dry rot, may be time to consider replacing the whole shock, unless they're old with very few miles. I tend to pull the pin early on shocks because bad shocks suck the life out of a vehicles handling and braking. Good shocks make the world right again. And it's a really cheap "mod".
  5. Apr 20, 2021 at 9:39 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Thanks for the input guys.
    I thought about it some more and at about 17 years/118k miles old, I think it's time for new front strut assemblies and rear shocks.
    Truck kind of seems floaty and I'd rather put new stuff on there.
  6. Apr 20, 2021 at 5:59 PM
    terrward
    terrward New Member
    2004 DC SR5
    +1 for replacing them. I just did 5100’s all the way around last week. My original 280,000 mile shocks were rusty and bushings were worn out. The truck rides much better.
    If you DIY, don’t be afraid of using the manual spring clamps for the front strut assemblies. The OEMTOOLS clamps are heavy duty and I had no issues using them to compress the springs.
  7. Apr 20, 2021 at 6:14 PM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    its over a 15 year old truck at this point slap in some bilstien 5100s front and rear and be done with it
    RustyShackle323 likes this.
  8. Apr 21, 2021 at 5:12 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    DO NOT go with Monroe under any circumstances. Avoid that shit like the plague.
    des2mtn, Festerw and Glock 40 like this.
  9. Apr 21, 2021 at 7:35 AM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    I had to do this last year. My bushing started squeaking.
    I agree with what everyone said.
    However I went with Monroe and I’ve not had any issues.
  10. Apr 21, 2021 at 1:44 PM
    Professional Hand Model
    Hand Protectors
    Jack McCarthy and bmf4069 like this.
  11. Apr 23, 2021 at 4:28 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    We use Monroe at the shop daily with little issue. I get a killer discount so for under $250 out the door for OEspectrum quick struts and rear shocks it's a no brainer. I won't be offroading, just a couple day a week driver and occasional tow/haul.
  12. Apr 23, 2021 at 7:27 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'll just put it this way, I'd rather have worn out bouncy struts than brand new monroes. These things ride like shit. They are HORRIBLE for a truck. If I wanted my truck to ride like a car, I'd buy a fucking car. Worst. Struts. Ever.
    Jack McCarthy and terrward like this.
  13. Apr 23, 2021 at 9:12 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    You don’t need a spring compressor to swap Coil Overs. I’ve never used one on a Tacoma, 4Runner or Tundra.
  14. Apr 23, 2021 at 10:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    This.
  15. Apr 23, 2021 at 10:16 PM
    alb1k
    Left Coast
    It's good
    Monroe on a Toy, not for me. Bilstein. KYB.
    bmf4069 likes this.
  16. Apr 24, 2021 at 5:46 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  17. May 4, 2021 at 3:55 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Well I'm glad I decided to do strut assemblies.
    Had to liquefy/air chisel off one of the 6 upper mounting bolts. Otherwise went smoothly. Truck rides nicely with the new stuff.
  18. May 5, 2021 at 7:10 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    When replacing shocks is anything needed other than what comes in the bilstein 4600 kit? Rubber upper top hats or anything?
  19. May 5, 2021 at 8:43 AM
    terrward
    terrward New Member
    2004 DC SR5
    Unless it’s damaged/wallowed out, you can reuse the top hat and nuts as well as the bolt/nut at the bottom.
    Jack McCarthy likes this.
  20. May 5, 2021 at 9:31 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    I would entertain reusing the coil springs if you want to, but personally after doing this job, if there's any rust on your mounts buy new ones. The studs/nuts looked good but one was completely stuck. So either try to break all 6 upper nuts loose before hand, or plan on replacing the mounts.
